Does this flywheel need resurfacing? - Alfa Romeo Bulletin Board & Forums
post #1 of 30 (permalink) Old 03-15-2010, 03:18 PM Thread Starter
r-mm's Avatar
There was some good chat on this board about when to resurface a flywheel. I agree with the ain't broke philosophy, but problem is I can't really tell if its broke or not. It sure is dirty, and seems to be somewhat marked by the surface of the friction disc (pic of that attached as well for reference). My instinct tells me that this flywheel is past the emery paper and wipe down level?
Presuming that it does need resurfacing... can you all share your experiences with lightening the stock flywheel? I think Jim K's book recommends taking 3-4 lbs off. Given that this is for his recipe for a streetable motor - I'm guessing that removing 3-4lbs will still yield a very drivable motor?
r-mm is online now
post #2 of 30 (permalink) Old 03-15-2010, 03:34 PM
FMG_V6_btb's Avatar
Saturday I took out 2 kg from my spider flywheel, I still have to take some photos, will post them when available.
I hope the engine will continue being drivable, but have some concerns about the ability of the idle speed controller (motronic) to control the idle in this "new" situation.
- SNO Director, Spain branch, Barcelona
- '90 2.0 Spider -- '93 164 QV -- '93 155 2.0 TS -- '02 156 2.5 V6 -- '?? FMG 3.8 Project
FMG_V6_btb is offline
post #3 of 30 (permalink) Old 03-15-2010, 03:40 PM
101/105guy's Avatar
But, you are running a scatter shield aren't you ??
'64 Guilia Spider
'67 GTV
'68 Giulia Super
101/105guy is offline
post #4 of 30 (permalink) Old 03-15-2010, 03:50 PM
Personally, I would not lighten the flywheel for street use, and the flywheel in the photo's I would have refaced. And seeing as everything is torn down, would also replace the clutch assembly while I was at it.
The last thing one needs is to put it all back together and have a problem.
I would also note that Alfa provided a steel flywheel for the GTA rather than a cast one when they wanted weight reduction.
Regards Ian
VeloceOne is offline
post #5 of 30 (permalink) Old 03-15-2010, 03:58 PM
FMG_V6_btb's Avatar
No shield, the flywheel has not loose any strength, just extra weight, from 9.3 kg to 7.3 kg without pressure plate, pressure plate is 4 kg more! and of course remains unchanged.
post #6 of 30 (permalink) Old 03-15-2010, 05:15 PM
crashmctavish's Avatar
its fine use it.
[I]Regards Keith, GTJ Twin Spark[/I]
crashmctavish is offline
post #7 of 30 (permalink) Old 03-15-2010, 05:16 PM
101/105guy's Avatar
I guess that it's something like bullfighting.....
'64 Guilia Spider
'67 GTV
'68 Giulia Super
post #8 of 30 (permalink) Old 03-15-2010, 05:25 PM
get real the clutch plate has 10 k +
Put it in & use it.
You need a containment sheild if you want to do silly stuff.
How deep are your pockets?
post #9 of 30 (permalink) Old 03-15-2010, 05:27 PM Thread Starter
r-mm's Avatar
Put it in & use it.
not following... 10k+? silly stuff?
I have a new clutch sitting next to me. Just debating whether or not to resurface the flywheel and if so, if I should have it lightly lightened.
r-mm is online now
post #10 of 30 (permalink) Old 03-15-2010, 05:31 PM
10 k miles
if you want to throw money at it fine, i would spend the cash elsewhere.
post #11 of 30 (permalink) Old 03-16-2010, 04:35 AM
Richard Jemison lightened my flywheel for me. It improves shifting, prolongs the life of the synchros and is not going to explode.
85 GTV6 3L
2011 Jaguar XKR
alfaparticle is offline
post #12 of 30 (permalink) Old 03-16-2010, 03:59 PM
Richard Jemison
Alfar7's Avatar
Flywheels
Your flywheel is fine and I would not consider resurfacing it.
The flywheel can easily be lightened 5 lbs with no safety issue.
Below are Pics I sen Gordon after playing with 3 1300/100 flywheels one afternoon. Weight went from 24+ pounds to 17 lbs. including ringgear.
Plenty of weigh for a mouse motor.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #13 of 30 (permalink) Old 03-16-2010, 06:25 PM
Gordon Raymond's Avatar
Thanks RJ. I know you have one like this too. Made by Ron Neal at Ausca about 1967-1970, 14 lbs. Lived behind a '65 GTA race engine for many years.
Gordon Raymond
Now:
Gordon Raymond is offline
post #14 of 30 (permalink) Old 03-16-2010, 06:31 PM Thread Starter
r-mm's Avatar
Can anyone recommend a machine shop familiar with Alfas in New England or NY? I'm back and forth between New Haven CT and White Plains NY.
r-mm is online now
post #15 of 30 (permalink) Old 03-16-2010, 06:43 PM
Here are a couple of others. First an old aluminum Tilton @ 9 lbs. It has a GTA disc and P.Plate on it that are much heavier than the flywheel. Alfar 7 knows how to fix that. The mouse is for Richard's "mouse engines". Last is another nice one I've been using. These weigh 7 lbs. These aluminum wheels don't come apart like either grey cast iron or nodular iron, and can be very light.
Gordon Raymond
Now:
