3.0 Verde Ignition wiring - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 04-24-2019, 05:52 PM Thread Starter
sportiva's Avatar
Hello All
I have installed a 3.0 Verde engine into my GTV6 now I would like to fit the Verde ignition loom and hardware. I have one problem the purple and white wire I have no idea what it connects too. Can anyone help
Cheers Glen
Glen 3.0 GTV6 2.0 156 JTS
sportiva is offline
post #2 of 4 (permalink) Old 04-26-2019, 04:53 PM Thread Starter
sportiva's Avatar
The purple/white is connected to the temp sender at the thermostat
sportiva is offline
post #3 of 4 (permalink) Old 05-01-2019, 01:36 PM
I have a similar problem. We're replacing the wiring loom in a 3.0 which has had the original loom hacked out. We have fitted the L-Jetronic, coil, ignition module and distributor and have connected them all with new loom. We have the ignition advance module the same as above but have no cable to connect it. If I buy or make this cable where does it connect to the other components?
CiaranONeill is offline
post #4 of 4 (permalink) Old 05-01-2019, 03:53 PM
The signal path is Hall effect sensor in distributor - IGN Advance computer - Bosch Ign Module - Coil
85 GTV6 3L
2011 Jaguar XKR
alfaparticle is offline
Similar Threads
1974 GTV Ignition Switch Wiring SinclairZX81 Electrical, Chassis & Lighting 13 07-12-2015 07:44 PM
For Sale: REAL NICE 1988 24 Valve 3.0 Litre Milano Verde; junglejustice Alfa Romeo Cars For Sale & Wanted 28 06-23-2014 12:10 PM
3.0 12V from a 164 vs. verde and milano install superloaf Milano/75 (1985-1993) 7 04-17-2010 11:39 PM
For Sale: Milano Verde in a GTV6 body (81 GTV6 3.0) TGOLD Alfa Romeo Cars For Sale & Wanted 16 10-19-2009 04:13 PM
URGENT help needed for ignition switch wiring Matthew K Alfetta & GTV6 (1972-1986) 11 03-11-2007 04:49 PM
