Strange Bosch problem - Alfa Romeo Bulletin Board & Forums
post #1 of 7 (permalink) Old 02-11-2019, 02:22 PM Thread Starter
trimaran's Avatar
I have a strange no start.
Neither cold start or run injectors are triggering.
All injectors have 12 v. All pins on computer check out. Have fule press and flow. Good spark.
I re did all ground wires. Temp sensors work. Ran perfectly turned off the next morning crank...but no start.
Any suggestions welcome.
Could a thermo time switch cause ALL the injtors to not trigger? What could affect both the cold start and the 4 run injectors to not trigger?
I am very familiar with Alfa and Bosch, but this has me stumped.
trimaran is offline
post #2 of 7 (permalink) Old 02-11-2019, 02:41 PM
BB Janitor
ghnl's Avatar
What model/year Alfa?
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is offline
post #3 of 7 (permalink) Old 02-11-2019, 03:12 PM Thread Starter
trimaran's Avatar
1985 spider
Thanks for any help
trimaran is offline
post #4 of 7 (permalink) Old 02-11-2019, 03:36 PM
BB Janitor
ghnl's Avatar
The Thermo Time Switch is part of the stand-alone Cold Start System. Thus I doubt a faulty TTS would prevent the regular injectors from working.
Check the link in my signature to a web site full of info about the L-jetronic system in our cars. I suggest going through all the checks - L-jet is a system - all the bits have to work properly for it to work at all.
- - Eric
don't read this
- -~ 1981 GTV-6 ~
ghnl is offline
post #5 of 7 (permalink) Old 02-12-2019, 11:11 AM
spiderserie4's Avatar
main relay perhaps? (the smaller one near the ecu) - one of the two pins numbered #87 is a common denominator between all 4 injectors.
The only common thing between all 4 injectors and the CSI is the fuel ecu.
was this car always a no-start in your ownership, or did it suddenly become so...?
(EDIT: oops, sorry, just re-read it happened suddenly....)
spiderserie4 is online now
post #6 of 7 (permalink) Old 02-12-2019, 09:18 PM
kredden's Avatar
I'd check the crank position sensors.
Kevin
Milano registry custodian(
kredden is offline
post #7 of 7 (permalink) Old 02-15-2019, 06:26 AM
I think if the flywheel sensors were bad, you would have no spark.
And you say you have spark but no fuel.
could be your '85 has the inertia switch fitted.
it will be a grey plastic cylinder contraption on the bulkhead (see photo) when they trigger the button pops up and fuel flow is cut.
try pushing the button down to reset it.
Alfa did away with them when L-Jet came out, but early L-jets still had them and were supposed to be bypassed (just tie the wire going to/from the gadget together, a Pink, I believe)
they are unreliable and can just activate going over a speed hump
Similar Threads
Really strange fuel delivery problem alfisti164l GT (1963-1977) 9 04-11-2017 07:05 PM
Strange problem hosob Spider - 105 & 115 Series (1966-1994) 2 07-06-2015 09:24 AM
Strange Clutch Problem Qmulus Spider - 105 & 115 Series (1966-1994) 5 03-23-2011 03:18 PM
strange interior light problem Alessandro 164 & 168 (1991-1995) 2 04-12-2007 10:15 AM
