Question about my compression numbers - Alfa Romeo Bulletin Board & Forums
post #1 of 2 (permalink) Old 11-08-2018, 02:18 PM Thread Starter
lawrencedesigns's Avatar
New Spider to me. 1988 Veloce. 55,00 miles. I know very little of its history but PO had headers installed that were changed out for smog test. They have been re-installed. It also came with Koni yellows and appears to have stiffer/lower springs.
This is my 5th Alfa, and I've never had one that had this much torque. My first was a new '74 Spider, so my memory has faded, but I don't think it made power like this one!
Without doing a teardown, I am wondering if there was engine work done. I ran a warm dry compression test today (3 passes) and got a consistent 200 lbs. even in all four cylinders.
Does that seem like a normal number? Seems high to me, which is a GOOD thing!!!
Keeth Lawrence
1988 Spider Veloce
lawrencedesigns is offline
post #2 of 2 (permalink) Old 11-08-2018, 03:55 PM
Richard Jemison
Alfar7's Avatar
CR
That`s higher than a typical 10 to 1 motor. But remember with the intake cam retarded as it is, overlap is severely reduced and the exhaust cam is a faster ramp design than earlier versions again reducing overlap compression losses.
Measure from the top of the #1 spark plug hole to the piston top at TDC and ask another Series 4 Motronic engine owner to do the same and compare.
You probably have a well sealed engine. That`s good!
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
