Pertronix for v6? - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By alfavulcan
post #1 of 7 (permalink) Old 10-23-2018, 09:33 PM Thread Starter
alfavulcan's Avatar
Pertronix for v6?
One of my back burner projects is an 87 spider with 164s v6 coupled to a 95 borg Warner t-5 from a Mustang and using 3 IDF Weberís. I will be using an 81 gtv6 distributor and was wondering if anyone has used a pertronix or similar electronic ignition setup to replace the original early 81-83 style sensors with its unavailable amplifier. Would also be a back up for my 81 gtv6. Thanks!
Milanoguy likes this.
87 graduate, 81 gtv6, 91 164s, 73 berlina 79 Mille miglia GONE: 76 alfetta gt, 74 berlina, 85 gtv6, 79 spider
alfavulcan is offline
post #2 of 7 (permalink) Old 10-24-2018, 06:38 AM
There is a good chance that the inductive sensor in the distributor will fire a GM HEI module or one of the Bosch modules for inductive sensors. That would just be a wiring change instead of messing with the guts of the distributor.
2011 Jaguar XKR
alfaparticle is offline
post #3 of 7 (permalink) Old 10-24-2018, 07:31 AM
Richard Jemison
Alfar7's Avatar
Distributor
As Ed said that distributor will trigger various Bosch (VW/Volvo/Mercedes etc) as well as Crane or MSD capactive ignitions.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #4 of 7 (permalink) Old 10-24-2018, 07:58 AM Thread Starter
alfavulcan's Avatar
I have researched posts about using various Bosch modules but havenít seen a definitive answer. Seeing how simple some of the aftermarket ignition systems are got me to thinking about my application
post #5 of 7 (permalink) Old 10-24-2018, 08:06 AM
Google Bosch BIM024
2011 Jaguar XKR
post #6 of 7 (permalink) Old 10-24-2018, 08:47 AM Thread Starter
alfavulcan's Avatar
That I will. Saw reference to it in another post. Thanks for the clarification!
post #7 of 7 (permalink) Old 10-24-2018, 09:05 AM
If I had an earlier type dizzy I would hook it up and test it on the bench but I only have a later, hall effect spare. Let me know if i can help.
2011 Jaguar XKR
