Setting static timing on a Marelli Plex? - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 07-29-2014, 04:22 PM Thread Starter
Hey gang,
I'm trying to get a 2L SPICA engine started that has been sitting for over a year.
The gas is probably not great, but I can get it to pop a few times, but it won't stay running.
I know from previous experience the Marelli Plex has a goofy curve that's realy short, so to get maximum advance sometimes you have to live with a high idel or hard starting.
I'd just like to get the static timing set and see if that helps starting, but I can't find the procedure.
Anybody here know where it is?
Thanks!
Ian
Ian Lomax - Current: 1973 Berlina, 1984 GTV6, 1987 Milano Platinum "racecar"
Past: 71, 74 Spiders, 2x 74 Berlina, 74 GTV, 76 Alfetta GT, 88 Milano 3.0, 97 164LS
archeologist is online now
post #2 of 4 (permalink) Old 07-29-2014, 04:59 PM
When I ran Marelliplex (with modified advance curves) I eyeballed the rotor with the pickup at TDC so that the motor would run. Then I set the max advance and forgot about the static. I doubt that it is possible to set the static timing accurately.
2011 Jaguar XKR
alfaparticle is offline
post #3 of 4 (permalink) Old 07-29-2014, 06:19 PM Thread Starter
I just need it close enough to run. I will try eyeballing it.
Thanks!
post #4 of 4 (permalink) Old 09-26-2014, 08:34 PM Thread Starter
Got it running, now trying to dial it in to run smoothly at low RPM.
