Ignition advance curve for TS engine - Alfa Romeo Bulletin Board & Forums
post #1 of 5 (permalink) Old 03-08-2006, 07:40 AM Thread Starter
ZeNiTh-PbArM's Avatar
Hello,
i'm currently installing an aftermarket ignition system on a TS engine (from a 75 2.0TS) to have it run on carbs. The cams are stock, the engine has a rebuilt head, runs on 98 unleaded and has Lodge plugs.
I wonder if anybody has info about ignition maps to feed the new ecu?
I can make it work with or without vacuum correction, so a basic ignition advance vs rpm curve would already be enough to start the engine.
any help appreciated.
Best regards,
zp
ZeNiTh-PbArM is offline
post #2 of 5 (permalink) Old 03-08-2006, 04:48 PM
Alleggerita's Avatar
Jim Steck of autocomponenti would probably be a good person to talk to.
Generally, twin spark needs way less advance, especially at higher rpm than single plug.
Alleggerita is offline
post #3 of 5 (permalink) Old 03-08-2006, 10:25 PM Thread Starter
Hi,
Thanks for the answer i'll email him soon!
Best regards,
zp
post #4 of 5 (permalink) Old 03-09-2006, 08:00 AM
Bruce Colby's Avatar
I have one of Jim Steck's mechanical advence distributors on my '65 Sprint GT which is running a 2-L TS with 45DCOE's. I asked Jim about the advance curve and he said he set it up to be the same as a GTA. I set the timing to 28 deg at 4500 rpm and that seems to work fairly well. However, I think it could use a bit more advance at higher rpm, about 1 deg per 1000 rpm would be nice.
Bruce Colby - Street = '69 1750 GTV/TS; Track = '65 SGT/TS, '89 E30, '72 914/6
gone to new homes
- '71 Jr. Z, '69 1750 Spider, '62 Spider
Bruce Colby is offline
post #5 of 5 (permalink) Old 03-09-2006, 08:09 AM
FWIW, stock GTA was 29 degrees max and Autodelta GTA was commonly 35 degrees max.
