24v Injector and coil pack wiring - Alfa Romeo Bulletin Board & Forums
post #1 of 1 (permalink) Old 01-23-2006, 12:58 AM Thread Starter
Hi Can anyone tell me the pin numbering and which pin does what on the engine side of the round multipin inj. and Coil - engine loom connector?
From investigating other posts it seems there are common coloured wires for the injectors so could do with knowing which pairs go to which pin, if that makes sense.
I'm connecting up a MoTec ECU directly to that connector and need to know which wires go to which cylinders to direct the Sparks and injection to. I've sussed the sequence, but I don't want to have to go to all the trouble of taking the plenum off again and all the connectors apart to find out what colour wires go where.
can anyone help? Anyone got a 24v engine out in bits?
Thanks very much
Rob S
Sando is offline
