nissan ecu conversion. - Page 3 - Alfa Romeo Bulletin Board & Forums
post #31 of 32 (permalink) Old 05-23-2011, 01:45 AM
Storm_X's Avatar
so i kinda had the right idea ?
"Alfa Romeo built to excite .. Some dream of driving the ideal.. I drive it"
Storm_X is offline
post #32 of 32 (permalink) Old 05-23-2011, 11:59 PM
Duk
Duk's Avatar
Originally Posted by Storm_X View Post
can you just control the main dizzy through the ecu using 4 coils to the main 1st spark, and then just leaving the 2nd dizzy/CAS standard ? as the 2nd spark just runs off the cams and i assume it doesn't need the power unlike the main spark.
The ECU doesn't control the distributor. In Brad's case, the Alfetta distributor provides a pulsed signal (2 signals per crank revolution) to let the ECU 'sort of know' where the engine is.
That pulse will typically be at about 0-20* BTDC of each cylinder.
The ECU does everything else. But the position of the Alfetta distributor (in Brad's case) will also determine the base ignition timing and this must be set to match what the ECU is sending out during idling. Any advancing or retarding of the Alfetta distributor will effect all timing values at all rev and load points.
Duk is offline
