What's wrong with this picture? - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 11-22-2010, 08:11 PM Thread Starter
Biba69's Avatar
Again I want to say that if I get another L-Jetronic car in, I'll get the necessary manual - though do have one for the GVT6/Milano.
This can't be right (variable cam hardware) since there was obviously something that was up against the hole above what I'll term the valve.
Should it be correct: (a) what does that empty hole do or is for? (b) what holds the gold metal plate in place...glue? (c) there wasn't a gasket on the solenoid unit was there?
I did remember the valve's O-ring.
Sorry to ask these details.
Biba
Biba69 is offline
post #2 of 4 (permalink) Old 11-23-2010, 03:37 AM
kredden's Avatar
Hope this helps.
Kevin
Milano registry custodian(
kredden is offline
post #3 of 4 (permalink) Old 11-23-2010, 03:50 AM
Trained (ex)Professional
1953-2018 RIP
papajam's Avatar
A) the empty hole is one of two threaded holes for the flathead machine screws that hold on the plastic sparkplug wire holder
B) the gold metal plate is held in with a (currently missing) allen head bolt
C) no gasket
D) the solenoid plunger is in backwards; the 'disc' goes on the inside of cam cover
papajam is offline
post #4 of 4 (permalink) Old 11-23-2010, 11:40 AM Thread Starter
Biba69's Avatar
Thanks Jim and Kevin. Call me crazy, but the diagam seems to definitely show the plunger and O-ring in the upper hole and the screw in the lower one. I scratched my head and thought that somethng was definitely amiss here.
I found this photo (tiny section of the entire engine) and then physically duplicated it, screw on top, plunger and O-ring (will be) in the lower hole.
On another note, thanks Jim for the reminder regarding the sparkplug wire holder. I just checked and the new Magnor wires won't fit inside. Sure wish they made a slightly larger wire holder.
Biba
Biba69 is offline
