Programmable Engine Management using stock Bosch wiring - Page 5 - Alfa Romeo Bulletin Board & Forums
post #61 of 64 (permalink) Old 12-02-2012, 09:55 AM Thread Starter
iachella's Avatar
And another update. I needed more space in the shrink wrap so I had to add another tube in parallel. I may re-do the whole thing in a much neater fashion after the car is running well. The parts are not that expensive and I anticipate a mistake or two in the wiring that will require a snip and solder or two.
I plugged it into the car's Bosch pigtail, turned the key on and the ECU light came on. The software recognized it and I downloaded the pre-loaded program to the laptop. I guess that only tells me that I got the power wires correct.
Stefano
Concord, CA
iachella [at] gmail [dot] com
iachella is offline
post #62 of 64 (permalink) Old 12-02-2012, 07:44 PM
kredden's Avatar
Stefano,
Where did you find the Bosch style pins?
Kevin
Milano registry custodian(
kredden is offline
post #63 of 64 (permalink) Old 12-03-2012, 06:19 AM Thread Starter
iachella's Avatar
I found the Bosch pins at Eagle Day. It's under Electrical | Terminals for Electric Housing | Female/Male Blade Terminals, and it's type - 3-7210.
Here is a link to the part:
Female Blade Terminals 3-7210, 3-7211
Stefano
Concord, CA
iachella is offline
post #64 of 64 (permalink) Old 12-03-2012, 06:38 AM
kredden's Avatar
Kevin
kredden is offline
