My race TS almost complete - Alfa Romeo Bulletin Board & Forums
 16Likes
post #1 of 36 (permalink) Old 12-13-2018, 09:55 AM Thread Starter
Send a message via Skype™ to Veloce75za
So this has been a long road but we are nearly there. It is probably one of the trickiest engines to build because it uses so many parts from so many engines and suppliers.
I am happy to share as much info as anybody would like to know but the basic spec is as follows
155 TS Head on Nord block with 75 front cover. 90mm crank, mono sleeve and fuel injection. Do not try this at home.
Anyway, nearly there! Best Christmas wishes!
Veloce75za is offline
post #2 of 36 (permalink) Old 12-13-2018, 11:11 AM
Seems like you built Novamotor F3 engine
Sent from my Z957 using Tapatalk
Max Pershyn is offline
post #3 of 36 (permalink) Old 12-13-2018, 01:11 PM
kpc655's Avatar
very nice! are those the Jenvey TBI units? i'm interested to hear how you like them.
kpc655 is offline
post #4 of 36 (permalink) Old 12-13-2018, 03:04 PM Thread Starter
Yes! Pretty close to that. Lol
post #5 of 36 (permalink) Old 12-13-2018, 05:59 PM
I would be interested to know the build, and choices (reasons etc.). A few people seem to be moving to the 155 head, is it that much better, how?
What sort of HP/KW are you expecting?
I have a good 2L TS out of a 91 Alfa75. I also have a good 2L out of an Alfetta that was built for my Duetto. Im thinking of using the crank and rods from that with then pistons from the TS to up the compression and retain the gearbox spigot. Run the original injection until I decide on throttle bodies. I just want to get the thing in the car (GTJunior).
I really like those jenvey ITBs.. are they as good/better than std 40mm ITB?
Craig_m67 is offline
post #6 of 36 (permalink) Old 12-14-2018, 12:40 PM
hunttheshunt's Avatar
One should show me any real hp advantage on 155 head over 75 head.
In PRACTICE on a dyno, not in theory.
I had several engines with 155 heads on a dyno, but never discovered any hp advantage over 75 heads.
Veep and giulia_veloce like this.
hunttheshunt is offline
post #7 of 36 (permalink) Old 12-14-2018, 12:47 PM
kpc655's Avatar
Personally, i prefer the 155 because it looks better. A bit more era correct if you ask me (!)
kpc655 is offline
post #8 of 36 (permalink) Old 12-18-2018, 03:03 AM
Veep's Avatar
If it runs on ITB, why use a manifold with a corner in it? the (said) advantage of the 155 head is the straight inlet tract. Which now is not straight anymore.. In that there is no difference with the 155 head, only the corner is in different place.
I agree the 155 has a cleaner more classic look (with the right cam cover...) , even more so when the ribs are removed.
davbert likes this.
Veep is offline
post #9 of 36 (permalink) Old 12-18-2018, 06:41 AM
If you take a look at 164 with 1962 and 1995 engine (both with catalysts), you can notice the difference in specific torque and the torque curve.
1962 has 95.3 Nm/l, 1995 - 96.7 Nm/l
Also the torque curve of 1995 is flatter and longer, the engine has 193Nm at 5000rpm, but 1962 has 187 Nm at 4800rpm
So, the 1995 engine is more elastic and has better specific torque. However specific power of both engines is almost the same, 73.7 hp/l (1995) and 73.9 (1962). You are right, even in theory, there is no advantage of 155 head in a case of maximum or specific power. The only one difference, the maximum power is shifted from 5800 to 6000 rpm
Probably in tuned engines there is no noticable difference but based on the factory characteristics they improved the engine
post #10 of 36 (permalink) Old 12-18-2018, 07:21 AM
any good pics of the 75 vs 155 heads? appearance wise and the intake tract angle?
davbert is offline
post #11 of 36 (permalink) Old 12-18-2018, 07:38 AM
kpc655's Avatar
There's a really good thread on the comparison's. The valve angles / and runner angles are basically the same between heads. The main diff is that the 155 has a relief @ the top entry point from the intake for the injectors.
There are some other minor differences (dep. on your view). For example, the 75 head will only work with a 75 front cover, whereas the 155 will work with any 105 front cover.
kpc655 is offline
post #12 of 36 (permalink) Old 12-18-2018, 07:48 AM
Subtle's Avatar
Subscribe.
Bob,
Subtle is offline
post #13 of 36 (permalink) Old 12-18-2018, 07:53 AM
As Chirico described in his book the main advantages of 155/164 1995cc engine are static ignition (lack of wear and tear parts), improved intake air flow and more compact size (because of the different VVT)
The increased engine capacity (very close to the physical limitations) allowed to overcome disadvantages of catalyc converter.
Also AR engeneers improved a torque delivery
post #14 of 36 (permalink) Old 12-18-2018, 08:41 AM Thread Starter
So my reasons are as follows.
In South Africa 75s were never sold. It almost impossible to find a 75 engine. Happily though we had many 164s and 155s in 8V so naturally this engine is easier to obtain. I wanted to stick to the 105 block and in my opinion this is the best way to make it all work. I already have a NOS 90mm crank in another engine and the Nm is much better with this crank. Using the Monosleeve allows for the safe use of 85mm Spruell pistons and thus a 100cc more than a 1962cc engine. As far as the looks go I believe the 155 head to be better looking than the clumsy 75 one. Personal choice and supply I guess.
As far as power goes, what you put in is what you get out. Unless you have back to back tested all the options then power figures and advantages of one over the other is all just useless opinion.
I have never seen a dyno graph of an engine like mine so one cannot speculate. I wanted a monosleeve TS injected engine but could not afford a real GTAm engine so this will just have to do for now.
Happy to share Dyno figures once installed but my 90mm 105 engine is much better than my identically built 88.5mm engine. Same everything!
Obviously one has to use 156mm rods in the 90mm stroke engine.
I would be very happy if this engines makes even 1hp more than my Nord 90mm engine. Very happy.
simon johnson and Max Pershyn like this.
post #15 of 36 (permalink) Old 12-18-2018, 12:15 PM
Max Pershyn likes this.
Seliquella is offline
