Building a 200HP Twin Spark - Page 4 - Alfa Romeo Bulletin Board & Forums
 1Likes
post #46 of 256 (permalink) Old 11-26-2010, 07:39 AM
That'll be interesting. My 1600 and 2L (ca 1974) both have bronze OEM for intake and exhaust. When did the cast iron come in?
Robert
60sRacer is offline
post #47 of 256 (permalink) Old 12-02-2010, 06:22 PM Thread Starter
69alfa's Avatar
Replacing Gear Box Studs With Bolts
This will make it much easer to remove just the motor or just the gear box .I used Ez_lok Inserts for Metal
Block with Studs
Removed the Studs One came out by Hand no double nutting required he said double nutting
Stainless M8 1.25 Inserts comes with Loctite
Holes Drilled Tapped and super cleaned
Ready to be inserted
[SIZE="2"]David Munro[/SIZE]
Toronto ON Canada
1969 Spider JR Twin Spark
69alfa is offline
post #48 of 256 (permalink) Old 12-02-2010, 06:34 PM Thread Starter
69alfa's Avatar
Finished
The loctite will be fully cured in 72 hours .
You can get a kit from Paul Spruell Block-rear-stud-replace-studs-with-bolts-
I had the tools for the job so all I needed were the inserts and bolts .
It was a fairly easy job with the motor on the stand . I think it would be just as easy with the gear box out and the motor in place and the car on a lift . Not sure I would want to try it with the car on jack stands . Unless you need to get your blood pressure up for some reason .
Toronto ON Canada
69alfa is offline
post #49 of 256 (permalink) Old 12-02-2010, 06:53 PM Thread Starter
69alfa's Avatar
Cleaning Head Studs
Before
After
A bit of a pain to get them clean from top to bottom .
I used green sanding pad and Loctite Penetrating fluid .
Any thoughts on how to stop them from getting rusty again ?
Toronto ON Canada
69alfa is offline
post #50 of 256 (permalink) Old 12-02-2010, 11:11 PM
AlvaroSeco's Avatar
Nice topic.... super-interesting.
subitocorse.com - Digital resource for classic transxale Alfa Romeo cars
AlvaroSeco is offline
post #51 of 256 (permalink) Old 12-03-2010, 11:39 AM
I never had much of a rust problem.
use antifreeze that should take care of most of it.
all motors I have seen with rust damage is due to lack of antifreeze.
you could also paint them with something. or electric plate them with something nickle.
or even gold. They have kits at the jewelry making places that use a few batteries wired to a brush and a bottle of plating stuff and you kinda just paint it on.
and I bet google has a ton of info on that too.
1987 black Milano Verde, 1987 (made in 1986)blue $200 gold with ABS and LSD
1972 White spider 2000 Veloce
slyalfa is offline
post #52 of 256 (permalink) Old 12-03-2010, 11:44 AM
Alfajay's Avatar
How about painting them with anti-seize ? This is the stuff I use on the tapers of tie rod ends, steering wheels, and the like. Works like a charm for those applications.
Alfajay is offline
post #53 of 256 (permalink) Old 12-03-2010, 02:51 PM Thread Starter
69alfa's Avatar
The studs were not badly rusted . Just me wanting to have everything perfect.
And I do use Anti-freeze . I'm Canadian we can extract it from our blood .
I think it would be more work than it is worth to pull the studs out to plate then.
I found this thread about stud removal http://www.alfabb.com/bb/forums/engi...studs-how.html
Not going to try that any time soon.
Toronto ON Canada
69alfa is offline
post #54 of 256 (permalink) Old 12-03-2010, 08:12 PM
who said pull the studs use the brush on type of plating.
slyalfa is offline
post #55 of 256 (permalink) Old 12-03-2010, 08:38 PM
...Any thoughts on how to stop them from getting rusty again ?...
You might try some black oxide on them to keep them from rusting while unassembled, 'though with a good antifreeze you shouldn't have a problem once its closed up. I'd clean them up with a good wire brush to get the thread roots clean.
Robert
60sRacer is offline
post #56 of 256 (permalink) Old 12-04-2010, 09:05 AM
you can prolly use rust converter jell to treat the bolts.
If I am not mistaken, it has phosphoric acid which coverts the bolt iron surface to rust resistant iron phosphate surface
worth a try.
andres
amoreno is offline
post #57 of 256 (permalink) Old 12-04-2010, 11:44 AM Thread Starter
69alfa's Avatar
I like the gel idea . Thanks
Toronto ON Canada
69alfa is offline
post #58 of 256 (permalink) Old 12-04-2010, 05:47 PM
60sRacer is offline
post #59 of 256 (permalink) Old 12-12-2010, 04:19 PM Thread Starter
69alfa's Avatar
All Clean
I got the block all cleaned up and took off all the extra bits from the casting .
Now that's better
Toronto ON Canada
69alfa is offline
post #60 of 256 (permalink) Old 12-12-2010, 04:51 PM
GTV4EVR's Avatar
Hi Dave
What product did you use?
[FONT="Comic Sans MS"]Ken Lee
Alfa Dogs #13
Oakville, ON[/FONT]
73 GTV
[SIGPIC][/SIGPIC]
GTV4EVR is offline
Tags
alfaholics, carrillo, engine cleaner, jim kartalamakis, paul spruell, twin spark
