Montreal Horn Wiring Issue - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 05-22-2019, 11:00 PM Thread Starter
Kiwi Veloce's Avatar
Hi,
The horn on my Montreal has stopped working and I have traced it to a bad connection on the Blue wire to the horn ring. The weird thing is when I activate the horn ring the wire moves but no connection. I have run a temporary wire from the black earth wire to the ring and lo and behold the horns work.
Question is - is there anyway I can check the blue wire connection or replace it WITHOUT having to take the steering wheel off?
Help appreciated.
69 1750 Veloce Spider Road/Race
1974 Montreal and 2004 156 Ti
Kiwi Veloce is offline
post #2 of 4 (permalink) Old 05-23-2019, 05:24 AM
USTA BE AN AD-MIN
ossodiseppia's Avatar
As you well know, the horn "buttons" only act as a ground when they are pushed. Somewhere behind the center of the wheel, you're not getting that connection. If you've checked the blue wire for continuity with ground, then you'll need to pull the steering wheel.
I have a similar issue with the steering wheel on my car. Two of the "buttons" work and the third does not. It's not a priority at the moment, but I'll need to remove the steering wheel to investigate.
ossodiseppia is online now
post #3 of 4 (permalink) Old 05-23-2019, 01:46 PM
Maybe the wire by the steering box? they break.
AlfasRule!
1972 Montreal (The Pumpkin)
1975 Alfetta Sedan
1975 Alfetta Coupe Race Car
1982 Spider
1984 GTV-6
1984 GTV-6 Verde (GiGi)
1987 Milano (Da NEW Winta Beata)
1987 Milano Verde(Da kREDden Mobile)
alfasrule is offline
post #4 of 4 (permalink) Old 05-24-2019, 05:11 PM
r-mm's Avatar
Ground the blue wire to known good ground. Honk or no honk? It runs to the horn relay thru the steering column, box.
Other wire is soldered to ring on wheel and i would guess more likely the culprit.
If anything the failure mode of the blue wire is likely nonstop horn. Name:  IMG_6460.jpg
'73 GTV bare metal project... nearing 'car' status
E30 Daily - '65 912 project... no longer in waiting
r-mm is online now
Similar Threads
Montreal Horn Relay alfajp Alfa Romeo Montreal 17 12-22-2015 07:58 AM
Montreal door Gasket fitment issue IRONBLOCK Alfa Romeo Montreal 4 09-11-2015 05:54 AM
Montreal Starter Solenoid Wiring Question alfajp Alfa Romeo Montreal 4 07-06-2015 04:24 AM
Horn Wiring rshirer Milano/75 (1985-1993) 0 03-31-2012 05:24 PM
79 Spider Horn Wiring alfafan61 Spider - 105 & 115 Series (1966-1994) 1 01-14-2009 06:06 PM
