Lost High Beams 1967 1600 Duetto - Alfa Romeo Bulletin Board & Forums
post #1 of 11 (permalink) Old 04-28-2019, 08:16 AM Thread Starter
Junior Member
1967 1600 Duetto
Yesterday while on a wonderful drive through Napa, CA. The following happens.
1. I see a very brief puff of smoke from under, or near my dash board, to my left.
2. I pull over immediately and turn off everything.
3. I examine under the dash, looking for burnt or hot wires. To my surprise I find nothing. Not even a linger hint of smokey/burnt odor.
4. As I check out what works, and what does not work, I find that I have lost my high beams (these were on when it happened, though it was not even dusk yet). I have also lost my dash/gauge lights.
5. Everything else, including the low beams work fine. We drive home, leaving the lights off and now I'm trying to find the cause. All fuses are good, I cleaned the contacts at the fuse box on all four sets of fuses, 2 for high beams, 2 for low beams, even replaced the fuses with new ones just in case.
My questions
My hunch is that perhaps the high beam postion in the steering column switch is bad, and might that be the puff of smoke I saw since nothing else appears to be hot, burnt melted etc.???
Is there a fuse or fuse link under the dash related to headlights that I'm missing?
I have a voltage/amp meter, how can I test the circuit for the high beams, and insure that the steering column switch high beam is or is not working? I'd like to test it before removing it if I can.
Is the fact that I also lost the dash/gauge light a clue? Why are these in the mix, but the low beams are still working??
Any help greatly appreciated. I also requested the wire diagram from Papa Jam. I'll check that out, hoping I can make heads or tails out if it. I've replaced the clutch, pulled the engine, etc. in the past, but wiring is a weak area for me. Circuits can get confusing, but I do get the basics, at least I think...
Thanks!!
Alfaflyer is offline
post #2 of 11 (permalink) Old 04-28-2019, 11:19 AM
Alfajay's Avatar
Yes, I think that's a good hunch. Now that you have verified that the fuses are OK, there isn't much else in the circuit.
Nope
You know that power is getting to the switch, since the low beams still work, so no need to check power to the switch. You could verify that power is not coming out of the switch to the two high beam fuses, while it is getting to the low beam fuses.
Can't answer that one in detail. How about your parking lights - do those still work? I would have thought that the dash/gauge and the parking lights were controlled by the same contacts in the column switch.
OK, here's where someone gives you the lecture about relays....
'63 Guilia spider
Alfajay is online now
post #3 of 11 (permalink) Old 04-28-2019, 11:35 AM Thread Starter
Junior Member
Thanks for the response, yes parking lights still work. I've also discovered that it is the dash lights on the speedo and the tach that are out, (as well as the high beams) at least I think, pretty bright out, I'll pull those and check to make sure, either way. But the other gauges are lit.
post #4 of 11 (permalink) Old 04-28-2019, 12:45 PM
Alfajay's Avatar
OK, that makes a bit more sense. I'm 99% certain that the failure of the dash lights on the speedo and the tach are a separate problem from the high beams. Check the dash lights for a bad ground, broken wiring, burned-out bulbs, etc. Your voltage meter will help diagnose this one.
My guess is still that your high beam failure is internal to the switch behind the steering wheel. Once you have confirmed that, there is no inexpensive or simple solution - you have to replace the switch. Yea, you can try spraying contact cleaner in there, or chanting over it, but honestly, the fact that it smoked suggests that it's, well, toast.
'63 Guilia spider
post #5 of 11 (permalink) Old 04-28-2019, 07:38 PM
slowcreek's Avatar
Nope
Who is gonna give the necessary lecture? It's super important.
It's Giuseppe's giubos, not Guido's guibos, on my 78 Alfas
slowcreek is offline
post #6 of 11 (permalink) Old 04-29-2019, 06:55 AM
USTA BE AN AD-MIN
ossodiseppia's Avatar
The poof of smoke could be grease that got between the contacts or, it could be that the contacts failed. There are a few pictures in the thread below that show the contacts inside the switch.
https://www.alfabb.com/bb/forums/705501-post18.html
You should be able to see the contacts through the holes on each side. Let us know what you see or don't see. If the contacts are all in place, some contact cleaner will help. You can also insert a small strip of emory cloth to really clean up the contacts.
ossodiseppia is online now
post #7 of 11 (permalink) Old 04-29-2019, 07:10 AM
slowcreek's Avatar
And, remove the negative battery cable to do the emery cloth.
post #8 of 11 (permalink) Old 04-29-2019, 08:05 AM Thread Starter
Junior Member
Thanks guys for the help. Now I have a direction to pursue.
I had requested a wire diagram from PapaJam, before I learned that he passed away. He was such a great help to so many of us. He even called me once to help me sort through a problem.
Any idea where I can get a wire diagram?
And I assume I pull the wheel, and remove the turn signal switch to get to the light switch, correct? (after I disconnect the battery!)
Any tips I need to know before I dive into that?
post #9 of 11 (permalink) Old 04-29-2019, 08:32 AM
Alfajay's Avatar
See: https://www.centerlinealfa.com/catal...diagram-duetto
And I assume I pull the wheel, and remove the turn signal switch to get to the light switch, correct? (after I disconnect the battery!) Any tips I need to know before I dive into that?
The headlight switch and turn signal switch are both in the same unit. So a lot of wires to disconnect & reconnect when you remove & replace it. Removing the steering wheel can be difficult - you will definitely need a puller.
'63 Guilia spider
post #10 of 11 (permalink) Old 05-02-2019, 08:08 PM Thread Starter
Junior Member
Thanks for the info. I received the wiring diagram today. This weekend I'll start tracing out the circuit and see what I find. The hunt begins.
post #11 of 11 (permalink) Old 05-14-2019, 08:28 AM
I also have the Duetto wiring diagram pdf from Pappajam and a source to print it any size. My copy is 20 x 26 and coated for dry erase markers. Quite handy. The printer is a friend, so I don't want to publish his info but I can anyone in touch if interested.
George
ghyounger is offline
Similar Threads
Stick shift knob removal :1967 Duetto 1600 lorencew Spider - 105 & 115 Series (1966-1994) 5 09-14-2017 12:41 AM
1967 Duetto 1600 Top WANTED Cuore Sportivo Spider - 105 & 115 Series (1966-1994) 17 06-19-2014 03:05 AM
Engine developments at Autodelta in the 1960's and 1970's Zagato_Olaf GTA (1965-1975) 25 05-11-2014 09:10 AM
Info on Duetto USA '69. 1600 or 1750 Berlinista Spider - 105 & 115 Series (1966-1994) 5 05-21-2011 12:20 AM
Steering squeal 1967 Duetto 1600. lorencew Spider - 105 & 115 Series (1966-1994) 6 11-30-2008 08:44 AM
