Loose wire in Alternator - Alfa Romeo Bulletin Board & Forums
post #1 of 3 (permalink) Old 04-27-2019, 12:14 PM Thread Starter
My alternator is only pushing out 11.64V so I opened it to have a look. There's a loose black wire on the stator that looks like it could have led to a terminal on the back of the alternator. It can be seen in the bottom part of the closeup pic attached. Anyone know if it needs to be attached to something? It looks like there are 3 other attachments that are fine (to the diodes?).
The brushes are also worn and will be replaced.
Ian MacRobert is offline
post #2 of 3 (permalink) Old 04-27-2019, 02:12 PM
iachella's Avatar
It looks like it could have been attached to a ring terminal and then by screw to that shiny hole just above it. Did you remove a screw there, or find any loose material bouncing around?
Stefano
Concord, CA
iachella [at] gmail [dot] com
iachella is offline
post #3 of 3 (permalink) Old 04-27-2019, 11:15 PM Thread Starter
Thanks for the reply! The screw hole that can be seen is for the fastener that holds the unit with the carbon brushes. There was no loose material floating around but it could easily have fallen out at some stage on the road...
What would this wire be for?
Similar Threads
85-88 Spider RPM, reference, sensor wire color codes Bultaco Spider - 105 & 115 Series (1966-1994) 13 01-11-2015 10:34 PM
Alternator Field Wire; 1986 Spider Moon96815 Spider - 105 & 115 Series (1966-1994) 28 07-14-2012 10:03 PM
164 Radio issues joep 164 & 168 (1991-1995) 2 06-19-2012 09:28 PM
splicing into alternator wire? bigpapajoe Alfa Romeo Topics Not Covered Elsewhere 6 02-27-2006 06:30 PM
Cooling fan elite38868 164 & 168 (1991-1995) 22 02-14-2006 01:15 PM
