1991 S4 - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By Salsa903
post #1 of 10 (permalink) Old 04-17-2019, 07:14 PM Thread Starter
1991 S4 - Left Tail lights
I have a very strange problem or problems with my 91 S4.
Lights off left and right blinker work fine.
Lights on left blinker works and right blinker does not work
Lights on left tail lights do not work and right tail lights work
All brand new bulbs.
Any suggestions would be greatly appreciated.
Thank you in advance.
Salsa903 is offline
post #2 of 10 (permalink) Old 04-22-2019, 11:52 AM
rafael's Avatar
Did you check fuses?
Spider 2.0i 1992 | GTV 2000 1971 | Giulia Spider 1963
rafael is offline
post #3 of 10 (permalink) Old 04-22-2019, 11:57 AM
Gubi's Avatar
I'd start by checking and cleaning grounds. Your right front headlight/sidelight grounds likely have a problem.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is offline
post #4 of 10 (permalink) Old 04-22-2019, 04:48 PM Thread Starter
I checked the fuses. I will check grounds. Thanks
Salsa903 is offline
post #5 of 10 (permalink) Old 04-22-2019, 06:04 PM
lgbalfa's Avatar
Send a message via Skype™ to lgbalfa
Sounds like fuses but since you checked that, I wonder what it could be.
Please keep us posted.
1992 Alfa Romeo Spider Veloce, 2017 Alfa Romeo Giulia, 2018 Volkswagen Tiguan SEL Premium
lgbalfa is offline
post #6 of 10 (permalink) Old 05-11-2019, 07:22 PM Thread Starter
I cleaned the grounds on left rear quarter panel, the ground on battery, grounds on both headlamps, cleaned and tightened grounds on tail light assemblies and grounds on passenger rear side of the engine block.
Also replaced 3 of the sockets on the tail lights. They were a little corroded. This is a New Mexico car and the ground locations were not bad at all.
Last of all I replaced the flasher relay.
Now left hand blinkers with lights on do blink but barely. Would never pass inspection. Also lights on the left side are very bright compared to the right side. When the blinker on the left is on it blinks super fast compared to the right side.
Not sure what else to do other than check the fuses again since I did all of this work.
Salsa903 is offline
post #7 of 10 (permalink) Old 05-12-2019, 05:16 AM
spiderserie4's Avatar
there are 2 grounds left and right of the radiator on the upper beam, each with 3 or 4 ground wires....which are for side lights and also for the front blinkers.
Since front blinker grounds might also affect the rears, it'd be worth removing and thoroughly cleaning both of these.
photo shows the one on left near the screen filler.
And the rear light plug? you have checked voltage coming from that?
spiderserie4 is online now
post #8 of 10 (permalink) Old 05-12-2019, 08:42 AM Thread Starter
Thanks Spiderseries4.
I cleaned those grounds.
I wonder if I reversed the splices on the new sockets it would matter?
Will check the voltage and fuses again.
Thanks again for your response.
Salsa903 is offline
post #9 of 10 (permalink) Old 05-12-2019, 12:18 PM
cannot say, but I would try swopping the light units around, just plug them in, swopped over, obviously removed and laying in the trunk (I think this is possible, same plugs I believe), then see if the fault follows the light unit or not.
If it does, then fault lies in unit, if not then it must be the wiring.
Dom
post #10 of 10 (permalink) Old 05-12-2019, 05:36 PM Thread Starter
Switched the lamp assemblies and the issue went to the other side.
I reversed the wires on the socket of the lower outside tail lamp assembly and everything worked!!
Got it!
Thanks everyone for your input.
spiderserie4 likes this.
Salsa903 is offline
Similar Threads
Alfa 164 - Alfisto Steve's Maintenance Tips Alfisto Steve 164 & 168 (1991-1995) 377 07-11-2019 02:19 PM
For Sale: Alfa Romeo Auction in New Jersey Falfa116 Alfa Romeo Cars For Sale & Wanted 72 02-02-2017 10:34 AM
For Sale: 1991 Alfa 164 Full Electric Drive Train islandbayy Alfa Romeo Cars For Sale & Wanted 5 01-15-2016 11:48 AM
FS 1991 Automatic Spider & 1983 Veloce & 1991 164 BrewThack Alfa Romeo Cars For Sale & Wanted 8 09-07-2007 07:26 AM
I know it's been asked a million times Nipper Milano/75 (1985-1993) 27 08-24-2007 06:23 AM
