Looking for troubleshooting directions for a dead fuse terminal - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By Gordon Raymond
post #1 of 5 (permalink) Old 02-23-2019, 06:20 PM Thread Starter
Hi guys-Electrical troubleshooting is a bit of a black arts thing for me. I have a number of accessories not working-running lights, tail lights, fan, instrument lights etc and have not worked since I bought the car-1974 GTV (Euro delivery)
Fuses all pass a continuity test and have been cleaned. The fuse terminal block however is not passing a continuity test when the fuses are pulled in fuse slot #1 and #6. My owners manual shows 1-4 as being main devices (so broad as to be not helpful and #6 shows as Indicating devices
My wiring diagram is hard/impossible to read so I'll probably end up buying one of those large laminated ones. That being said, I'm hoping for suggestions or a link to a previous post that may shine a light (pun intended) on my path to enlightenment.
Please advise and thanks
Austin Alfa is offline
post #2 of 5 (permalink) Old 02-23-2019, 07:29 PM
BB Janitor
ghnl's Avatar
My knowledge of automotive electricity is limited to the smoke theory - that electricity moves through the wires by smoke. When the smoke escapes things stop working...
As for Alfa fuse boxes, I always suggest a couple of things. 1) if the fuses are of unknown vintage replace them. Somehow the bullet type fuses in our cars can appear OK and even pass a test with an ohm meter but in use they fail to allow sufficient electrons to flow. Especially the fuses with the aluminum strip. I prefer the fuses with a brass strip. If needed, gently bend the fuse contacts so they are held firmly in place.
And B), unhook and lower the fuse box down, turn it around and check that all the connectors in the back are fully inserted. It can help to one by one remove and re-insert each connector. Doing this scrapes off any slight corrosion making for a more reliable connection.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
post #3 of 5 (permalink) Old 02-23-2019, 08:26 PM
Gordon Raymond's Avatar
In one Ferrari,a '65 I had the copper wire inside the screw tensioned hole in the back of the fuse block oxidize, turning black. Continuity was lost despite a tight screw. I shortened the wire, re-stripped the same amount of insulation, reinstalled the shiny copper wire (braided) and all was well. I thought about removing every wire, and tinning the bare copper ends with solder before re-inserting and tightening ALL those screws. Then I though... "You FIXED it. All the rest are bare copper and NOT black. Call it GOOD". Years later it was still fine, and NO SMOKE had ESCAPED!
alfaloco likes this.
Gordon Raymond
Now:
Gordon Raymond is offline
post #4 of 5 (permalink) Old 03-23-2019, 04:44 PM
r-mm's Avatar
Fuses 1-4 are all "always hot" circuits which should operate when the car is off, key is removed. These include interior lights, brake lights, wipers, turn signals, hvac blower. These four terminals are "bussed" on the hot side meaning a single 10ga wire from the starter feeds all four. I would look to see if this wire has +12v at both of its ends. Do you have attached wiring diagram from papajam? There are many versions of it, there may be one more correct to your Euro car than I am attaching.
'73 GTV bare metal project... nearing 'car' status
E30 Daily - '65 912 project... no longer in waiting
r-mm is offline
post #5 of 5 (permalink) Old 03-23-2019, 04:49 PM
r-mm's Avatar
Found a pic of the fuse box showing the bussing in question. Do you have +12v at all times at the bussed side of fuses 1,2,3,4?
r-mm is offline
Similar Threads
Electronic suspension? surfer69 164 & 168 (1991-1995) 15 01-24-2019 09:14 AM
Think I blew a fuse? Radio AND speedometer are both dead, at once. Joe Papa Sr Spider - 105 & 115 Series (1966-1994) 32 10-02-2011 09:41 PM
102 fuse block needed, car is DITG IRONBLOCK 1900, 2000 & 2600 (1950-1968) 2 01-01-2011 03:29 PM
Blinkers dead, strange fuse. flamebero Electrical, Chassis & Lighting 3 04-20-2009 05:50 AM
How to use "spare fuses" in 91-93 164 fuse box Alfisto Steve 164 & 168 (1991-1995) 0 08-02-2008 08:18 PM
