1986 S3 switch for reversing light - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 06-17-2018, 12:45 PM Thread Starter
Hello,
I am trying to find a switch for reversing light for my S3 Spider. Reverse light does not have a signal while it goes up to transmission box. Is that switch inside transmission box or somewhere outside? I somehow struggling to find it while the car is not lifted. And Do you know if i have to disassemble gearbox to reach that switch or is it easily reachable?
orangutangas is offline
post #2 of 6 (permalink) Old 06-17-2018, 12:54 PM
sloboy89's Avatar
Originally Posted by orangutangas View Post
Hello,
Switch is inside bell housing on front of gearbox. Transmission must be removed to replace the switch. Bad design.
Rich
'85 Spider Veloce
'17 Giulia Ti Sport
sloboy89 is online now
post #3 of 6 (permalink) Old 06-17-2018, 01:04 PM Thread Starter
Oh my...It will take some time. Do you know i have to buy a new better or is it possible to restore easily that not working switch?
post #4 of 6 (permalink) Old 06-17-2018, 01:08 PM
spiderJohnNH's Avatar
Send a message via Yahoo to spiderJohnNH Send a message via Skype™ to spiderJohnNH
Many have commented that a switch failure is very rare. Usually, as in my experience, the connectors all need to be cleaned up. This is a common problem caused by corrosion as the wiring runs underneath exposed to the elements.
Are you sure that there is no signal in the wires coming out of the bell-housing?
Sent from my SM-T710 using Tapatalk
John R
So. NH, USA --'87 Spider Veloce
See you along the road - member of AROC/AONE
other current members of the fleet
2017 VW Jetta Tsi
2006 Subaru Outback - almost a driveway requirement in VT & NH
2007 Toyota Corolla
previous
2009 VW Jett TDi (Deer took this one out)
1984 Mercedes 300TDT wagon, rust took that one
1972 Mercedes 280SE, got in straight swap for the Discovery
1996 Land Rover Discovery
1986 Volvo 740 Turbo Wagon
1962 VW Bug - 6 volt
1974 Triumph Spitfire - wobbly driveshaft kept destroying stuff
1972 Triumph Spitfire - got totaled while parked at DMV
some others that were less interesting
spiderJohnNH is offline
post #5 of 6 (permalink) Old 06-17-2018, 01:15 PM Thread Starter
I will try once again to do a double check, bu spent almost whole weekend and haven't got that signal working and going to the end into rear light. And signal ends somewhere near transmission box..
post #6 of 6 (permalink) Old 06-17-2018, 02:06 PM
sloboy89's Avatar
You should have two wires going into the bell housing. One of them should be hot with the key on. When the gearbox is put in reverse, that should close the switch mounted inside the bell housing. You should be able to diagnose whether the switch is working fairly easily.
With the car securely on jack stands, get underneath and find the connectors in the two wires (should be near the gearbox). Separate those connectors. With the key on (engine off), use a voltmeter to see if you have a voltage (~12V) between the pink wire on the car side and ground. If you don't, then your problem may not be the switch but rather may be a fuse (fuse 7?) or a broken wire. If you do have a voltage on the wire, then you need to check the switch.
To check the switch, put an ohm-meter across the two wires that go into the bell housing. (Again, do this with the car off). When the car is in reverse, the resistance should be very low, indicating a closed circuit. When the car is in neutral (or any gear other than reverse), the resistance should be infinite, indicating an open circuit. If it meets these tests, the switch is working.
If the car passes both of these tests but the reverse lights still don't work, it could be a faulty ground or burned-out bulbs. The reverse lights share a ground with the tail lights, so if those work but the reverse lights don't, that isn't likely.
Rich
'85 Spider Veloce
'17 Giulia Ti Sport
Tags
reverse light, reverse light switch, transmission
