Fuel pump will not go on - Alfa Romeo Bulletin Board & Forums
post #1 of 3 (permalink) Old 05-29-2018, 08:35 AM Thread Starter
After my 78 spider running great, i tried to start it and did not hear the fuel pump run when key was in the MAR position.
It obviously did not start.
I assume that it is a bad ignition switch. I have one ordered from Alfaholics, however, does anyone have an in house fix to get it running before the new switch comes in.
I could really use a ride this week as the weather is great!!
milford is offline
post #2 of 3 (permalink) Old 05-29-2018, 08:58 AM
Trained (ex)Professional
1953-2018 RIP
papajam's Avatar
Do the gauges and dash warning lights work when you turn the key? If so, the ignition switch is not the problem. I'd check the fuelpump fuse (it's in the small 2-fuse fusebox next to the large 10-fuse fusebox).
papajam is offline
post #3 of 3 (permalink) Old 05-29-2018, 09:00 AM Thread Starter
I checked all the fuses. all are good. the fuel pump goes on as i advance the key into the starter position. but when it returns, pump goes off.
I jumped the pump and it started right up.
milford is offline
