-   Electrical, Chassis & Lighting (https://www.alfabb.com/bb/forums/electrical-chassis-lighting/)
-   -   123 Ignition - wrong ignition parts or even ignition for my 2000 GTV? (https://www.alfabb.com/bb/forums/electrical-chassis-lighting/610330-123-ignition-wrong-ignition-parts-even-ignition-my-2000-gtv.html)
Che 09-17-2017 04:50 AM
1 Attachment(s)
To all 123 experts,
I bought my 2000 GTV Bertone (1974) some three years ago with an existing 123 ignition setup. I had to exchange the distributor cap, but the suggested cap for the 2000 engine didnít fit.
My cap needs asymmetrical mounting brackets - whereas the suggested cap from the 123 homepage recommends caps with "symmetrical" brackets, pls. see attached screenshot)
My mechanic fitted the BERU VK154 (replacement for the VK105 he said) and now I experience a lot of misfiring. Funny enough, I did not experience misfiring with the old asymmetrical cap that was mounted before.
The suggested BERU VK106 for the 2000 engine did not fit. When I consulted the part dealers, I found out that the VK154 is suggested for 1300 engines. This could explain the misfiring...?
As I understood, the 123 ignition should fit all Nord engines 1300-2000. So, to all the 123 ignition experts:
- Could it be that I have an old or wrong 123-model that didn't fit all the Nord engines? The official 123 ignition homepage suggests that the cap (for ex. VK106) fits all engines, there is no mentioning of different caps for different engines 1300/1600/etc. And there is certainly no mentioning of asymmetrical caps like the BERU VK154 (new), or VK105 (old)
- What would you recommend me to do?
Many thanks in advance and regards from Switzerland
Sergio
Alfar7 09-17-2017 01:46 PM
Cap
Why would you buy a cap for the engine???
Buy a cap for the 123 (and the model of the 123) that you have!
alfaparticle 09-17-2017 05:01 PM
Che 09-17-2017 10:02 PM
Thanks for your replies - so I understand it doesn't matter which cap I use as long as it fits...
I was confused by the informations given by the part dealers, who differ in terms of which cap fits which 105 engine size
hunttheshunt 09-17-2017 10:31 PM
That's mainly wrong ! If your dizzy requires an 'asymetrical' cap, you shouldn't use the symetrical one as it will cause misfire ! And: It's possible to get the 'wrong' one type fitted to every Bosch housing when a PO possibly 'modified' the clamp mounts over the years.
BOSCH caps are not engine capacity related but only distributor related. For 105/115/116's series w/Bosch dizzies there are 3 different caps available - 2 of them are of the 'asymetrical' type and are interchangable.
