Repairing a gtv hazard switch - Alfa Romeo Bulletin Board & Forums
post #1 of 9 (permalink) Old 01-03-2011, 03:24 PM Thread Starter
aralfa8589's Avatar
The round hazard switch on my '73 stopped working-the button wouldn't stay in the off position, so the lights flashed constantly. The following shows how I fixed it.
1. Removed the switch from the dash by unscrewing the threaded collar from the backside.
2. The switch is held together by a bunch of snap tabs. Removed one tab and cut away the outer part where the tab latches. Could probably have removed more tabs but this worked.
3. Carefully pried and depressed other tabs until the switch came apart
4. The switch opened up.
5. The "female" half has a little lever with a pin that tracks in some slots on the "male" half-the part that pushes in and out. Can also be seen in pic 4.
Jeff Lang
'85 GTV6 3L, '78 Alfetta Sport Sedan
aralfa8589 is online now
post #2 of 9 (permalink) Old 01-03-2011, 03:45 PM Thread Starter
aralfa8589's Avatar
Part deux
6. The little pin rides in these plastic slots on the push button piece. These were worn so that the switch wouldn't latch in the off position.
7. A plastic shim inserted behind the pin arm made it ride a bit deeper in the plastic grooves.
M first shim wasn't quite thick enough so I used a slightly thicker piece. I should have measured the thickness, but I think it is a seat of the pants deal. My shim came from the tab on one of those terminal covers from a new battery. I reassembled the switch it worked like a champ. This saved me about $80, and since the hazard lights will be used rarely on any Alfa, will last a long time. Did you remember to keep track of the wire connections?
Hope this helps someone.
Jeff Lang
post #3 of 9 (permalink) Old 07-05-2011, 10:16 AM
This will definitely help me. Mine also just suffered the same fate, and I had sticker shock when I saw that new ones were $80. I'll attempt this tonight.
Thanks!
Ian -
74 Berlina
Ian Lomax - Current: 1973 Berlina, 1987 Milano Platinum "racecar"
Past: 71, 74 Spiders, 2x 74 Berlina, 74 GTV, 76 Alfetta GT, 88 Milano 3.0, 164LS
archeologist is offline
post #4 of 9 (permalink) Old 08-29-2011, 12:00 AM
pietrogiulia's Avatar
This was a HUGE help! Thanks so much!
Do you happen to know which wires went where, because I'm certain that none were connected when i removed it...
And also, what's the best way to get behind the dash to have a look and reconnect this switch?
Thanks so much in advance!
1983 Alfa Romeo GTV
pietrogiulia is offline
post #5 of 9 (permalink) Old 08-29-2011, 03:39 AM Thread Starter
aralfa8589's Avatar
Pete-
I'm away from home for a week, so I can't help wth the connections.
Jeff Lang
post #6 of 9 (permalink) Old 08-29-2011, 03:47 AM
Not a problem Jeff, thanks very much for getting back to me though! I'll have a play around with it tomorrow, and thanks to you, my hazard switch is as good as new.
Cheers
1983 Alfa Romeo GTV
post #7 of 9 (permalink) Old 10-05-2012, 10:08 AM
.AA.'s Avatar
Thanks Jeff!! This is awesome and works great. A piece of zip tie for a shim worked for me.
1971 1750 GTV
.AA. is offline
post #8 of 9 (permalink) Old 08-27-2013, 07:47 PM
goats's Avatar
Beautiful!
Came out of work today and flashers were on, switch popped in the OUT position, and would not latch in. Came home, searched 'gtv hazard switch', took it out (take out the two screws for the dash pod, pull it out, then easy access), levered the switch open, and in my case the little metal arm was bent away from the groove - bent it back, voila, all back together and works like a champ!
Connections - black wires (2) to center lug
Blue/Black to "L' lug
Blue to "R' lug
White to '49a' Lug
Thanks Jeff great job!
goats is online now
post #9 of 9 (permalink) Old 07-21-2018, 05:33 PM
Thank you soooo much, those information was just needed . Fixed in 10 🙂
Miricanu is offline
