Repair soft mounts - Alfa Romeo Bulletin Board & Forums
 6Likes
post #1 of 35 (permalink) Old 07-22-2019, 03:57 PM Thread Starter
Repair soft mounts
Our 2.L spider motor was converted to twin Webers (40 DCOE) with the soft mounts. Earlier I sprayed the soft mounts with starting fluid and sure enough the idle speed increased and smoothed out. Sounds simple enough, but being the cheap skate I am are the soft mounts easily repairable? In our window business we use a product from Dow Corning called "123". It is a silicone tape about 1/8" thick and comes in various widths from 1" to 12". My thought is to clean the surfaces thoroughly with lacquer thinner, lay a few beads of Dow Corning 795 (bedding sealant) and apply the 123 tape. Sounds simple, has anybody had success/failure with this repair?
I have never had this product not work in our window world as long as the surfaces are clean and dry.
930cabman is offline
post #2 of 35 (permalink) Old 07-22-2019, 04:10 PM
Gordon Raymond's Avatar
See the post on "thoughts on hole in piston" before even considering not replacing insulator / isolators. These ARE a replacement item, like tires, windshield wiper blades and drive shaft rubber donuts. Not replacing deteriorating rubber items is ALWAYS a false economy.
My opinion only, from my own experiences.
divotandtralee likes this.
Gordon Raymond
Now:
Gordon Raymond is offline
post #3 of 35 (permalink) Old 07-22-2019, 05:20 PM Thread Starter
Gordon,
Thank you for your wisdom, at $25./each it sounds like good value.
post #4 of 35 (permalink) Old 07-22-2019, 07:31 PM
ANY time the Webers are off, and the engine has more than a year running time, the intake manifold comes off and new insulator / isolators are installed, a new intake manifold gaskets as well as good quality insulator / isolator gaskets. Then whatever Weber work was done, you do not need to worry about airleaks downstream.
Gordon Raymond
Now:
post #5 of 35 (permalink) Old 07-23-2019, 05:53 AM
USTA BE AN AD-MIN
ossodiseppia's Avatar
In my opinion, there are a few places on any car that you should not go the cheap route on. They are:
Brakes
Steering
Engine
ossodiseppia is offline
post #6 of 35 (permalink) Old 07-23-2019, 06:18 AM
There are reports of quality variations in these things and that Pirelli are best if you can find them.
Gordon Raymond likes this.
2011 Jaguar XKR
alfaparticle is online now
post #7 of 35 (permalink) Old 07-24-2019, 05:16 PM Thread Starter
I have been using the soft mounts that came with a Euro intake manifold/Weber carb setup a few years ago. I found time today to remove them and they look old. Is there a life expectancy for the soft mounts? Is Centerline a good source?
thanks
post #8 of 35 (permalink) Old 07-24-2019, 05:50 PM
65Sprint's Avatar
I have had some that last ten years and some that seem to barely last four or five. Could be due to the quality variation Ed referred to. Centerline is probably as good as any other supplier.
Rich Hanning
65Sprint is online now
post #9 of 35 (permalink) Old 07-29-2019, 05:48 PM Thread Starter
Great, we sourced a new set of carb mounts and was able to install last weekend. Got her all together, adjusted the valves, checked compression (170# cold) and fired her up. Same lopey idle, bouncing vacuum gauge and still appears to have a vacuum leak. Engine idling speed increases and smoothes out when starting fluid is sprayed at the soft mounts, before and after the new mounts. I am hesitant to slather the carb mounting and soft mounting gaskets with Permatex sealer, but cannot think of where else a vacuum leak could exist?
post #10 of 35 (permalink) Old 07-29-2019, 07:08 PM
65Sprint's Avatar
I share your lack of enthusiasm for applying sealer to the soft mount gaskets but if they are leaking, not many options. Can you tell if the leak(s) are occuring between the mounts and the manifold or between the mounts and the carbs? It would be nice to be able to identify exactly where the problem exists.
Rich Hanning
post #11 of 35 (permalink) Old 07-30-2019, 04:13 AM Thread Starter
Yes, I am not sure how to isolate the source.
I have heard of a smoke test where smoke is introduced into the intake manifold under a very small amount of pressure. Nothing pops up when searching "smoke test"
post #12 of 35 (permalink) Old 09-04-2019, 07:16 PM
Yachtman's Avatar
The smoke test is fantastic for testing leaking windshields and rear glass��.
(Not sure why I added that, but....it's true!)
[B][I][U]Current[/U][/I][/B]
1984 Spider Veloce Deluxe
1969 GT 1300 JR
1969 1750 Spica Spider Veloce
1963 MGB
1952 MG TD
Others??!!!😃😃
Yachtman is offline
post #13 of 35 (permalink) Old 09-04-2019, 08:29 PM
slowcreek's Avatar
Why must you have soft mounts?
It's Giuseppe's giubos, not Guido's guibos, on my 78 Spider and Sport Sedan
slowcreek is online now
post #14 of 35 (permalink) Old 09-14-2019, 09:00 PM
EldridgeM's Avatar
The aluminium mounts are much better. My last set of rubber mounts were made by Akron. Didn't last more than a few months.
Sent from my SM-G950F using Tapatalk
'73 Euro 2000 GTV (2008 - present)
'85 Giulietta 116 (2001-02)
EldridgeM is offline
post #15 of 35 (permalink) Old 10-02-2019, 04:16 AM
duemila's Avatar
Don't you think Alfa would have made alluminum mounts, if they were better? Rubber damps vibrations, Alluminum does not.
Oo-\°/-oO
duemila is offline
