Weber Carb set up - Page 3 - Alfa Romeo Bulletin Board & Forums
 4Likes
post #31 of 37 (permalink) Old 07-23-2019, 10:04 AM
Thanks, back to the basics. If all the systems are not correct fooling with the carbs is a waste of time.
Hoping to get this issue cleared up and then on to setting the Webers up. We have an Innovate LM 2 with the tail pipe adapter. Has anyone had luck with this setup? I have never used it, but does look somewhat confusing. We will not be using the OBD function or the RPM function.
930cabman is offline
post #32 of 37 (permalink) Old 07-23-2019, 03:17 PM
slowcreek's Avatar
Does it have a way to just monitor air/fuel ratio? Commonly referred to as AFR.
It's Giuseppe's giubos, not Guido's guibos, on my 78 Spider and Sport Sedan
slowcreek is offline
post #33 of 37 (permalink) Old 07-23-2019, 04:48 PM
Yes, I need to learn how to operate it.
BTW: I have a flip phone, no smart device for me
post #34 of 37 (permalink) Old 07-23-2019, 07:27 PM
65Sprint's Avatar
I know nothing about the Innovate devices but capturing the AFR and RPM simultaneously is highly desirable.
Rich Hanning
65Sprint is offline
post #35 of 37 (permalink) Old 07-23-2019, 07:43 PM
I would say it is essential for setting up carbs. Even on a dyno where you don't have to steer or brake it is hard to determine at what rpm an AFR dip or bump occurs by trying to simultaneously monitor the tach and the AFR readout.
2011 Jaguar XKR
alfaparticle is offline
post #36 of 37 (permalink) Old 07-23-2019, 08:32 PM
Push hard and live
DPeterson3's Avatar
Cheap soft mounts are very expensive.
Buy the best quality you can find.
Trust me on the Franck VF tube concept. Changes the entire thinking around Webers. Frankly, his explanations suck. But the tubes work.
Don P
Carson City, NV
Past Alfas...
Current Alfas
Oops. Add to the "present" list, 10204 01488, 2000 Touring Roadster project
And past...
1946 Luscombe 8A
And present...
64 Mooney M20E ("Rambo". My faithful steed for over 40 years) Over 55 years old, and just returned from a trip to Argentina in him
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is offline
post #37 of 37 (permalink) Old 07-26-2019, 12:05 PM
bfeng's Avatar
I have an Innovate AFR and use it both bung-mounted as well as with a tail pipe adapter. The tail pipe adapter can be less accurate at idle due to reversionary air flow contamination.
But under driving conditions I’ve found both mounting schemes provided consistent info. Makes tuning carbs much easier.
John F.
bfeng is offline
Tags
alfaholics, camshaft, jets, weber
