SPICA Filter Access - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 1 Post By divotandtralee
  • 1 Post By Roadtrip
post #1 of 8 (permalink) Old 05-02-2019, 08:15 AM Thread Starter
divotandtralee's Avatar
SPICA Filter Access
I know it hasn't been covered anywhere else that I can find... newbie silly question... Am I to assume you access the Spica oil filter from beneath the car and on a Spider have to remove the horn from the bracket first??
divotandtralee is offline
post #2 of 8 (permalink) Old 05-02-2019, 08:36 AM
USTA BE AN AD-MIN
ossodiseppia's Avatar
Do you mean the injection pump oil filter?
I just did mine, last week. I had to contort my hands and body and got to it from underneath. The horns on my car are in front of the radiator. So, nothing to do there. The engineers had no consideration for the folks who work on these things.
ossodiseppia is offline
post #3 of 8 (permalink) Old 05-02-2019, 09:48 AM Thread Starter
Yes, Brian.. This looks like a miniature cluster-muck.. no wonder these filters don't get changed. My horn sits right on top of it to make it even more "friendly".. You can barely make out the chasm in my photo. I can't even phathom the ideas of "burping" these that some guys do. Thanks
ossodiseppia likes this.
post #4 of 8 (permalink) Old 05-02-2019, 10:30 AM
Roadtrip's Avatar
Be careful with the small studs and nuts to not break them.
John Stewart
74 Spider
91 164S
Roadtrip is offline
post #5 of 8 (permalink) Old 05-02-2019, 10:54 AM Thread Starter
Yep.. care is my middle name.. Book says 21 In-pounds of torque... I think I can feel that.
post #6 of 8 (permalink) Old 05-02-2019, 12:24 PM
The general rule with the studs and nuts is to tighten figure tight and start the engine. When the oil starts to seep out around the plate slowly tighten the nuts until no more seepage.
Kim Boydell is offline
post #7 of 8 (permalink) Old 05-02-2019, 06:13 PM Thread Starter
Thank you
post #8 of 8 (permalink) Old 05-02-2019, 08:50 PM
Jim G's Avatar
You can just push the horn upwards and the bracket will bend enough to get to the 3 nuts.
A small short 1/4 inch flex head ratchet works well getting to the nuts.
I also use a small pick to put down the center of the oil filter housing to make sure the check valve is free. Over 30 years I have found a few that were stuck closed. Also make sure you clean out the sludge well. If you do it before doing changing the oil you can use brake cleaner to clean it out well. Then run the car for a few minutes then change the engine oil.
Jim G is offline
Similar Threads
Spica filter replacement JBNEPA Carburetors, Fuel Injection & Air Intake 2 12-28-2014 12:38 PM
Spica Oil Filter problems Eric W Spider - 105 & 115 Series (1966-1994) 9 07-02-2014 07:20 PM
Spica to Weber Conversion - Fuel Supply Luscombe1940 Carburetors, Fuel Injection & Air Intake 43 01-03-2013 10:44 AM
SPICA Oil Filter mlrose Spider - 105 & 115 Series (1966-1994) 6 07-01-2012 10:26 AM
Spica filter removal. Easy, but... SpiderWebb Carburetors, Fuel Injection & Air Intake 2 10-28-2007 02:34 AM
