Fuel injector hose replacement - clamps vs 'hats' - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By Joe149
post #1 of 9 (permalink) Old 04-14-2019, 03:30 PM Thread Starter
Member
I'm in the midst of replacing the fuel injector hoses on all injectors on my GTV6. I ordered the nifty kit from Centerline that includes hoses, and both the stock 'hats' for each end, as well as standard hose clamps.
I just removed the first hose, from injector and rail, using the recommended soldering iron, etc. What a PIA!! Can someone give me a reason to use the 'hats' instead of the clamps? I don't care about the look - I'd prefer that it be more easily maintainable. Another 12 hose clamps amongst the hundreds on the top end of that engine would, for me, be barely noticeable.
Do the stock pieces somehow provide a more secure fit? Were they used just because it was easier to assemble at the factory? Curious!
thanks in advance!
Joe
Joe
84 GTV6 | 95 M3 NASA/BMWCCA race car
Joe149 is online now
post #2 of 9 (permalink) Old 04-14-2019, 04:09 PM
BB Janitor
ghnl's Avatar
I don't think clamps would make any future service easier - the hoses would still be held quite firmly on the hose barbs*.
*assuming the hoses are the correct replacement size. The fuel rail to injector hoses are a specific metric size. 7.5mm ID IIRC. 1/4" is too small and 5/16" is too large.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
post #3 of 9 (permalink) Old 04-14-2019, 07:46 PM
I use clamps and so do my friends who race GTV6's. Ideal brand clamps are smooth and do not dig into the hose.
85 GTV6 3L
2011 Jaguar XKR
alfaparticle is offline
post #4 of 9 (permalink) Old 04-15-2019, 06:20 AM Thread Starter
Member
Seems like without the hats, I could cut the full length of the hose - and remove it much more easily?
Joe
post #5 of 9 (permalink) Old 04-15-2019, 07:33 AM
BB Janitor
ghnl's Avatar
I believe the reasoning behind using the soldering iron instead of a knife is to avoid nicking the hose barbs which might lead to a leak.
The only time the hoses need to be R/R'ed is when their life is nearing an end. In other words, R/R'ing the hoses isn't done for any other routine work.
- - Eric
don't read this
- -~ 1981 GTV-6 ~
ghnl is online now
post #6 of 9 (permalink) Old 04-16-2019, 05:30 AM Thread Starter
Member
Thanks Ed, as usual,
Joe
Joe
post #7 of 9 (permalink) Old 04-16-2019, 11:15 AM
This is the type that I use and as recommended by Al Mitchell
85 GTV6 3L
2011 Jaguar XKR
post #8 of 9 (permalink) Old 04-16-2019, 12:41 PM Thread Starter
Member
Yep - that's the kind I figured you meant - definitely what's needed for fuel lines. Summit Racing has them for $9 each - but I think Grainger has equivalents for less. Thanks!
Joe
Joe
post #9 of 9 (permalink) Old 04-16-2019, 03:04 PM Thread Starter
Member
Just went to garage and started removing hoses, thinking I'd have to order good hose clamps, and I find that the Centerline kit I ordered has those exact clamps. Thanks Centerline!
Joe
alfaparticle likes this.
Joe
Similar Threads
Are my plug wires bad and if so would that cause stalling after the car is hot? chairmankaga Alfetta & GTV6 (1972-1986) 301 11-27-2017 07:55 AM
Alfasud fuel tank enri Boxer Engined Alfa Romeos 6 05-23-2017 08:08 AM
fuel injection hose clamps.. bianchi1 Off-Topic Talk 3 03-09-2011 11:36 AM
Replacement fuel tank sending unit? Benjamin Carburetors, Fuel Injection & Air Intake 7 10-02-2010 11:14 PM
Replacement Fuel Sender 3 Spade Wiring? mikebgallagher Electrical, Chassis & Lighting 2 05-28-2006 01:18 PM
