SPICA Throttle Body rebuild - Alfa Romeo Bulletin Board & Forums
post #1 of 26 (permalink) Old 02-10-2019, 07:01 PM Thread Starter
r-mm's Avatar
Hello all -
Forum member John Jeffries kindly gave me a spare set of SPICA 2000 throttle bodies that I want to rebuild. My fully rebuilt, Ingram pump'd 2000 motor runs wonderfully but I suspect it having an air leak at idle as I have a persistent vacuum thru the bodies and have done all, yes all, the steps including using the AR factory stop set tool.
I have seen very few threads on rebuilding these and am not saying the bodies are definitively the problem but nonetheless I have them on the bench so will have a go at them.
I have one of them dismantled, the other soaking to break free a seized shaft. If anyone has experience here please chime in.
'73 GTV bare metal project... nearing 'car' status
E30 Daily - '65 912 project... no longer in waiting
r-mm is offline
post #2 of 26 (permalink) Old 02-11-2019, 07:20 AM
Roadtrip's Avatar
I don't, but I'm sure Wes Ingram would. He might know a common sized and available square seal for the shafts that you can get locally.
The brass screws that hold the butterfly plates will need to be mushroomed/staked, or maybe locktited to prevent them from falling out and being injected into the cylinders.
John Stewart
74 Spider
91 164S
Roadtrip is offline
post #3 of 26 (permalink) Old 02-11-2019, 07:59 AM
goats's Avatar
take the opportunity to open up/port the intakes, bring to a shop have em bored open more. Decrease the diameter of the butterfly shaft where it is in the airflow, and file down the screws that hold the brass butterfly plates to the shaft to get a minimal cross-section when fully open. See what you can do to get more air through there.
As for the seal, measure the three requirements (ID/OD/Depth) and got to motion industries to find a suitable seal.
goats is offline
post #4 of 26 (permalink) Old 02-13-2019, 11:04 AM
Q.V.'s Avatar
Location: Moscow, Russia -> Minneapolis, MN, US -> Lausanne, Switzerland
The seal size is 13x19x3mm. I bought mine from this store: Simply Bearings Megastore | eBay Stores
Also, look at this thread for part numbers etc.: https://www.alfabb.com/bb/forums/car...-question.html
1975 Alfetta; ex 1973 Spider; ex 1984 Alfetta Quadrifoglio Oro
Q.V. is online now
post #5 of 26 (permalink) Old 02-13-2019, 11:06 AM Thread Starter
r-mm's Avatar
Thanks that is exactly the info I was seeking!
r-mm is offline
post #6 of 26 (permalink) Old 03-03-2019, 01:29 PM Thread Starter
r-mm's Avatar
I found the parts needed at reasonable cost here:
https://www.thebigbearingstore.com/6...earing-7x19x6/ - there is a SS shielded and rubber sealed version, I opted for the later. The factory part is entirely open.
https://www.thebigbearingstore.com/1...tric-oil-seal/
well, I should wait to receive and install before I go saying these are the parts needed. Will update...
r-mm is offline
post #7 of 26 (permalink) Old 03-03-2019, 01:32 PM Thread Starter
r-mm's Avatar
I also spent some time cleaning one of the TBs. Put it in the ultrasonic then shot its exterior in some clear powder. Refinished or replace most of the hardware. The fiddly part will be insuring a perfect seal on the brass discs but that will come on reassembly when the bearings are here.
r-mm is offline
post #8 of 26 (permalink) Old 03-03-2019, 04:58 PM
horsewidower's Avatar
Very nicely done. I've pulled a couple of them apart, I'm waiting to see your experience with the new seals.
Bob
But wait there's more: View my 164LS thread:
horsewidower is online now
post #9 of 26 (permalink) Old 03-03-2019, 07:02 PM Thread Starter
r-mm's Avatar
These are the closest I've found to replace the brass screws. Right in every dim but 7.5mm dia head instead of 6mm. I believe this will fit or can be filed down some. If they work I'll have enough for the whole BB... packs of 100.
https://www.mcmaster.com/91700a317
r-mm is offline
post #10 of 26 (permalink) Old 03-03-2019, 09:06 PM
Jim G's Avatar
Call McMaster and give them the part number for the screw your showing. Then ask them if they can get it with the head size you need. They will take your number and call their supplier's and see if its available. They will usually call you back in 30 minutes to an hour. If they can get it they will give you the cost and a quote number.
I have done this many times. They have a really good customer service.
I just got 2 more.
Jim G is offline
post #11 of 26 (permalink) Old 03-03-2019, 11:37 PM
Rosenmöller's Avatar
As far as I remember I did use this one:
48-50-55 DCO 2/SP
Position 31 order Number 9320
Salutations from the Baltic sea
Bernhard
Rosenmöller is offline
post #12 of 26 (permalink) Old 03-04-2019, 05:22 AM Thread Starter
r-mm's Avatar
Thanks all. I already put an order in for the McMaster parts I linked to so I'll let you know if I can make them work, I'm optimistic I can. Seeing as I'll have 100 of them I'm happy to drop a few in the mail to whoever needs them and will still have a big supply in case I need to drill them out in the future, as I'll likely be using some loctite to keep them from being swallowed by my nicely rebuilt 2L.
r-mm is offline
post #13 of 26 (permalink) Old 03-06-2019, 03:32 PM Thread Starter
r-mm's Avatar
With some loctite and a jewelers file, I think this will work nicely.
Size:  224.6 KBName:  IMG_3803.jpg
Size:  228.1 KBName:  IMG_3804.jpg
r-mm is offline
post #14 of 26 (permalink) Old 03-06-2019, 06:16 PM
Alfa69GTV1750's Avatar
What did you use in the ultrasonic cleaner to get the rust off the steel parts?
Mike
1969 GTV 1750
San Diego, CA
Alfa69GTV1750 is offline
post #15 of 26 (permalink) Old 03-06-2019, 06:41 PM
goats's Avatar
Again, think about the airflow that is needed through the ports. If you don't desire to open up the ports (ie remove some material to increase the ID of the bore) then do try to minimize the screw / shaft etc cross section.
Remember that the area of the bore is a squared function, so small changes in ID result in large changes to area (A = pi*r^2). Having that screw head sticking up like that is an impediment to air flow. This rebuild is a chance to gain some pretty large performance gains if you are so inclined.
Matching the outlet to the head inlet will also get more air in.
If you are not trying to goose up performance, then what you have ought to be just fine!
goats is offline
Similar Threads
Spica throttle body vac lines Boca Spider - 105 & 115 Series (1966-1994) 0 04-25-2016 09:59 AM
White Powder inside my Spica Throttle Bodies iachella Engine Conversions 8 06-22-2015 11:35 PM
For Sale: Alfa Romeo Throttle Body $30 pmreng Alfa Romeo Parts For Sale & Wanted 0 10-14-2010 02:49 PM
For Sale: Alfa Romeo Throttle Body $30 pmreng Alfa Romeo Parts For Sale & Wanted 0 10-14-2010 02:11 AM
FS: Alfa Throttle body pmreng Alfa Romeo Parts For Sale & Wanted 0 10-13-2010 01:31 AM
