Fuel Pressure gauge recommendations - Alfa Romeo Bulletin Board & Forums
post #1 of 8 (permalink) Old 10-15-2018, 06:57 AM Thread Starter
Crowbar44's Avatar
So I'm "fixing the fuel lines on my Weber converted '81 Spider. The PO actually had a return fuel line setup and I want to change it to the proper setup without a return, but I want to check the Fuel pressure to make sure it's a proper 3 PSI.
Does anyone have a recommendation for a good affordable Fuel pressure meter that will work with 8mm Alfa Fuel lines?
Also, where should I measure fuel pressure? Right before the carbs?
Many thanks,
GC
'81 Spider (Weber's, Euro Bumpers, Custom Interior) Ivorio over Red | '54 Austin Healey 100-4, Bone Stock save for M cam, Carmine over Black.
Crowbar44 is offline
post #2 of 8 (permalink) Old 10-15-2018, 08:13 AM
bruce1976spider's Avatar
Yes.... But first, I'd recommend you KEEP that return line!!
Reasons for loving a fuel return line:
1) Cooler fuel - flowing back to the tank means it isn't sitting there getting hot, at low throttle.
2) Pressure regulators LOVE flow - they have an easier job keeping pressure correctly at widely varying fuel flow demands
3) Pumps do not like being 'dead headed' - live longer healthier lives with constant flow.
All this is why modern cars have fuel loops!
Now - on the topic - measure and regulate at the carburetors. This gauge is working well for me : https://www.autozone.com/gauges-and-...ing/266125_0_0
50 years from now - how are we going to restore a "classic" microprocessor based modern car?? Alfas - 1980 Spider, 1987 Milano, 1976 Spider
bruce1976spider is offline
post #3 of 8 (permalink) Old 10-15-2018, 08:22 AM Thread Starter
Crowbar44's Avatar
Fascinating...It's funny, I attended a car show with my Spider this weekend, and a number of Alfisti suggested that the line should be dead-headed...but Bruce your comments make a great deal of sense, plus by keeping the return line I wouldn't have the issue of having to cap the existing mental return line under the car.
I was looking for a temporary fuel pressure gauge - not one that is permanently installed...though I really like Bruces setup...
What should the fuel pressure be if running a return line? Still 3 PSI?
Many thanks,
GC
post #4 of 8 (permalink) Old 10-15-2018, 09:24 AM
Many thanks,
GC
Yes, the PSI is the same - it's what Weber carbs want. You may want a slight restriction in the return line, to let the regulator work against (or the regulator might not be able to reach 3 PSI!!)
Originally, fuel lines were one-way, so the default seems to be "do it the old way"...
post #5 of 8 (permalink) Old 10-15-2018, 09:48 AM
I have been running a no-return fuel system on my Spider for at least 15 years. It is simple, fewer things to suspect if you are troubleshooting a problem. I have crewed for a few Alfa race cars with Webers and they do not use return lines. Some cheap regulators may need a return line but Filter King do not. Modern cars are using high pressure fuel systems that do require return lines.
2011 Jaguar XKR
alfaparticle is offline
post #6 of 8 (permalink) Old 10-15-2018, 10:21 AM Thread Starter
Crowbar44's Avatar
For those who don't run a return fuel line, how do you cap the metal return line under the car? I was thinking a short run of flexible line with a threaded bolt in the end of the line...any other thoughts? I'd rather keep the metal return lines in case the next owner wants to convert back to SPICAs...
post #7 of 8 (permalink) Old 11-01-2018, 04:23 PM
We are running an '85 spider with Weber conversion, electric fuel pump, regulator and gauge installed between the two Webers. 2-3 psi. I have not installed a return line and appears I will not. Probably close the line off at the tank end with a plugged fuel line.
930cabman is offline
post #8 of 8 (permalink) Old 11-01-2018, 08:16 PM
Return line or not depends on the fuel pump. The click-click pumps don't need a return line while the buzzing pumps should have one-but it's not a big deal if they don't. Modern fuel injected cars do not have a return line, but there is a bypass at the pressure regulator in the fuel tank.
Chas H is offline
