E-Fuel Pumps for Carbs - Page 2 - Alfa Romeo Bulletin Board & Forums
 8Likes
post #16 of 38 (permalink) Old 08-19-2018, 02:02 PM Thread Starter
AlessandroM's Avatar
thanks guys, that helped me quite a bit!
Learning, learning..
AlessandroM is offline
post #17 of 38 (permalink) Old 08-19-2018, 02:33 PM
Both the cube pump and the disc regulator that I owned were junk. Take the advice of the experts and buy an appropriate pump and a Filter King regulator. If you ask for advice and several experienced people tell you the same thing then you probably should trust them.
85 GTV6 3L
2011 Jaguar XKR
alfaparticle is offline
post #18 of 38 (permalink) Old 08-19-2018, 05:27 PM
Richard Jemison
Alfar7's Avatar
Fuel pump for Webers
I have this pump on the Duetto Race can, the Montreal powered "Coupe" with 4 DCOEs, my engine break in stand, and the Onan generator in my Motor home. All with pressure gauges show 3.0 to 3.2 PSI.
Cost $40.00
https://www.ebay.com/p/Electric-Fuel....c100005.m1851
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #19 of 38 (permalink) Old 08-20-2018, 12:01 AM Thread Starter
@alfaparticle
Two things:
- I already have the original fuel filter diaphragm that came with my car. I actually started testing with that but it didn't work that well hence I tried with the disc-one.
- Im totally listening to the experienced people but I don't see anything wrong in asking why people actually think it is superior. I will ultimately ask facet whether the cyl-type are more durable.
@Alfar7
I actually read in another thread that you are using that no-name pump which I found interesting and sort of brought me off the idea to buy the way more expensive pump.
Do you use any regulator?
Thanks guys
Alessandro
post #20 of 38 (permalink) Old 08-20-2018, 05:15 AM
Trained (ex)Professional
1953-2018 RIP
papajam's Avatar
@AlessandroM
I am curious as to why you are switching from the stock engine mounted mechanical pump to an electric pump.
papajam is offline
post #21 of 38 (permalink) Old 08-20-2018, 06:24 AM Thread Starter
@papajam
There's no definite 'hard' reason to it.
I don't daily my car and I don't want to always stress the starter to fill the bowls.
And I will eventually convert my car to EFI and thus making fuelpushing an external concern is something less to connect/disconnect when I revert to carbs (besides swapping the fuel pump obviously)
While more reasonable thats also why I swapped to an electric fan setup.
post #22 of 38 (permalink) Old 08-20-2018, 07:57 AM
1953-2018 RIP
papajam's Avatar
That's exactly the reason I use an electric pump as well. But only to fill the bowls. Then the engine runs on the stock mechanical pump.
The 30 some odd year old cube pump I'm using, mounted in the rear of the car, is activated via a toggle switch that is fed from the ignition switch. It pulls fuel from a stock, top discharge fuel sending unit. To start the car, turn on the ignition and then electric fuelpump. The electric pump then pushes fuel straight through the check valves in the mechanical pump (the check valves prevent fuel drainback FROM the engine, not to the engine). After the bowls are filled, turn off the electric pump and then start/drive the car as normal. The mechanical pump will pull fuel straight through the cube pump. A stock filter/regulator is installed in the factory location between the mechanical pump and the carbs.
An added benefit to this setup is that in the event of a stock pump failure, just turn on the electric pump.
papajam is offline
post #23 of 38 (permalink) Old 08-24-2018, 12:20 AM
Originally Posted by Gordon Raymond View Post
This is fairly simple. The correct fuel pump is the low pressure high volume FACET pump pictured below. It must be mounted back, by the tank, as this pump "pushes" fuel. It does not "pull" or lift fuel very well. If you wish to use an aftermarket filter / regulator, the best is the Filter King pictured below with an Alfa FRB 11 for comparison. The Filter King has a greater range of pressure adjustment than the FISPA FRB11. Fuel pressure should be set at 3# or less.
Hi Gordon,
is this Malpassi/King a good regulator as the King of your photo?
jacky71 is offline
post #24 of 38 (permalink) Old 08-24-2018, 08:10 AM
Gordon Raymond's Avatar
Not the exact one, jacky71, but they all function in a similar manner. I've seen small and larger versions, with and without pressure gauge. If you google Filter King, or look on E-bay you can see they make a few variations. Current production uses all fuel proof diaphragms and seals. These have been available for years, so I do not know how far back components were "fuel-proof". I do know that unless updated with a new diaphragm and bowl seal, original FISPA FRB 11's will leak, and original diaphragms will harden and fail. I restore / update a lot of these.
Racers use the larger Filter King, and like the built in gauge. I usually recommend the one with the gauge as these are not OEM FISPA for concourse, but used as replacements or for function. The gauge makes set up easier than temporary or permanent install of a separate gauge.
jacky71 likes this.
Gordon Raymond
Now:
Gordon Raymond is offline
post #25 of 38 (permalink) Old 08-24-2018, 09:21 AM
Not just racers
85 GTV6 3L
2011 Jaguar XKR
post #26 of 38 (permalink) Old 08-24-2018, 09:59 AM
Tom Frasca's Avatar
I read this post ...a few questions my mechanical pump went bad on my 1600. I replaced it (mechanical) and an inline filter. Other then having to crank it to get fuel to the carbs when it its for a while, all is well, and it starts immediately everytime and runs the stock 1600 with zero issues. Gordon keyed in on several issues , but the unknown is what is this fuel system connected to? My own preference is to K.I.S.S. if your running a stock setup. I do not have a pressure regulator and the stock 40 MM webers are set to spec.I rarely push it to 6000 but it will....and the plugs and AFR are all good..
Tom Frasca is offline
post #27 of 38 (permalink) Old 08-24-2018, 12:58 PM
It depends to a degree on the size of the float valves in your Webers. Bigger valves are less tolerant of higher pressure. My 45DCOE152's get sufficient fuel at WOT/7000 rpm with 2.5 psi. The float valves are 2.0 and 3.5 psi will cause them to flood.
85 GTV6 3L
2011 Jaguar XKR
Last edited by alfaparticle; 08-24-2018 at 04:04 PM. Reason: Changed float valve from 3.0 to 2.0
post #28 of 38 (permalink) Old 08-24-2018, 11:53 PM
Thanks for the very comprehensive answer as always.
Initially, I need a regular setup, so I was thinking of rebuild this model of regulator rather than a Fispa.
Buying today a revision kit I should be sure to find materials suitable for actual fuels.
Some advice on where to buy spare parts?
Thank you
jacky71 is offline
post #29 of 38 (permalink) Old 08-25-2018, 12:06 AM
Hi Papajam,
very interesting upgrades. What features must the pumps have for this system?
Thank you
Tom Frasca likes this.
jacky71 is offline
post #30 of 38 (permalink) Old 08-25-2018, 03:28 AM
Tom Frasca's Avatar
We had rarely driven the car, now that we(my wife and I) are retired we drive it with more frequency. I will install pump as you described. Always good to have a backup plan.(I do carry a spare). And, of course-some ignition bits and a AAA gold card!!! Which pump do you use?
