Spica Fuel Cutoff Solenoid Adjustment - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 1 Post By 91spiderNV
post #1 of 11 (permalink) Old 08-06-2016, 08:23 AM Thread Starter
tadslc's Avatar
1971 1750 Spider
Gone through several write-ups on adjusting the FCS and am a little confused. I guess it's par for the course...
I've gone through all the steps successfully until I get to the FCS adjustment.
#1 is the locknut that is 34mm (as close as I can measure). I have several tools specifically for this but nothing for this large a nut. But that's not my concern, I loosened it with some channel lock pliers easily.
After setting the engine speed to 2500 rpm's I turn the solenoid clockwise to find the max lean point the engine starts increasing in rpm's. I did 1 complete clockwise revolution and in continued increasing the rpm's. I never could tell it was missing. At this point I quit and returned the solenoid to the original starting position. Turning the solenoid ccw to riches just decreases the engine speed, I didn't go rich more than 1/4 turn from the original setting.
Is it possible to actually unscrew the FCS and take off? When I loosened the lock nut, the solenoid felt a little wobbly if I'm describing it correctly. When I turn it clockwise it starts feeling more solid. I'm curious if it's so out of adjustment that if I had kept rotating cw it would have eventually gone back the other way, reducing rpm's.
This is the first time I've tried to adjust this on this car and it's been a long time since I've dealt with the Spica system.
I know the car has been running rich, the gas mileage isn't great and the exhaust pipe is black and sooty but overall it runs pretty decent.
Any ideas?
Tad
Alabama
'59 Sprint
'59 Spider Veloce
'61 Giulietta Spider- Street
'61 Giulietta Spider- Race
'67 Giulia Super
'71 Spider Veloce
'17 Giulia Q
tadslc is offline
post #2 of 11 (permalink) Old 08-06-2016, 08:27 AM Thread Starter
tadslc's Avatar
Here's a side view of the FCS
Tad
Alabama
'59 Sprint
'59 Spider Veloce
'67 Giulia Super
'71 Spider Veloce
'17 Giulia Q
tadslc is offline
post #3 of 11 (permalink) Old 08-06-2016, 08:43 AM Thread Starter
tadslc's Avatar
After doing some more reading I unscrewed the solenoid and it came out in almost exactly 9.5 revolutions so I think the FCS is about right
Tad
Alabama
'59 Sprint
'59 Spider Veloce
'67 Giulia Super
'71 Spider Veloce
'17 Giulia Q
tadslc is offline
post #4 of 11 (permalink) Old 08-06-2016, 02:51 PM
Push hard and live
DPeterson3's Avatar
I recommend finding a dyno shop to use while setting the mixture.
Using the "at 2500 RPM" method, you should have someone adjusting the throttle to hold it at 2500, not set the throttle and have in increase or decrease as you adjust the FCS. It is an imprecise method.
On a dyno you can adjust the mixture to 0.1 within a few minutes.
Don P
Carson City, NV
Past Alfas...
Current Alfas
Oops. Add to the "present" list, 10204 01488, 2000 Touring Roadster project
And past...
1946 Luscombe 8A
And present...
64 Mooney M20E ("Rambo". My faithful steed for over 40 years) Over 55 years old, and just returned from a trip to Argentina in him
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is offline
post #5 of 11 (permalink) Old 08-06-2016, 05:03 PM
Roadtrip's Avatar
9.5 is a nominal starting setting. It well may be the correct one for your engine. Run it like this for a while and check plug color. If too rich, screw it in a half turn and check again after a while . . . and vice versa.
John Stewart
74 Spider
91 164S
Roadtrip is online now
post #6 of 11 (permalink) Old 08-08-2016, 10:43 AM Thread Starter
tadslc's Avatar
Thanks John, I had already increased it about 1/2 turn lean before I buttoned everything up to see if that made a difference. I'll keep an eye on things and see if this helps. Biggest problem is this isn't the best time of year (90+ degrees) to put miles on my car so it'll be a while
I'm just kinda curious what I was missing when following these write-ups. I was on a roll re the rest of my adjustments and this kinda stumped me.
John- I've also read some threads that you have an idle stop setting tool that you've been letting people borrow. Is this available?
Tad
Alabama
'59 Sprint
'59 Spider Veloce
'67 Giulia Super
'71 Spider Veloce
'17 Giulia Q
tadslc is offline
post #7 of 11 (permalink) Old 08-08-2016, 02:16 PM
Roadtrip's Avatar
Yes. PM me a mailing address and I'll send it out on Wednesday when I get back home.
John Stewart
74 Spider
91 164S
post #8 of 11 (permalink) Old 09-13-2019, 08:32 PM
Hi there everyone. I'm in the process of my first SPICA tune-up myself and have run into this exact issue of turning the FCS clockwise to lean the mixture but as per the original post here the engine speed seems to increase and I can't tell if there are any misses going on. I'm wondering what the ultimate solution was here? Are we just not listening to the engine correctly? Should I perhaps remove the FCS all together and then give it the standard 9.5 turns in and go from there adjusting every few drives?
shadowdd6 is offline
post #9 of 11 (permalink) Old 09-14-2019, 08:46 PM
slowcreek's Avatar
Keep going clockwise slowly. When the engine begins to "sour", not miss, note the position of the FCS. Slowly again, turn the FCS counter clockwise. The engine should begin to speed up and smooth. Keep going that direction until the engine "sours" again. Note that position. Turn the FCSto the point halfway between the 2 earlier noted positions. Should be pretty darn close.
It's Giuseppe's giubos, not Guido's guibos, on my 78 Spider and Sport Sedan
slowcreek is online now
post #10 of 11 (permalink) Old 09-19-2019, 11:59 AM
91spiderNV's Avatar
I installed an Air Fuel Ratio Gauge and set it using 2500 rpm. Just need to get a muffler shop to weld a bung and attach the sensor. $120 from Summit Racing, or some other parts store. This way you have some real numbers to guide you. You can run it either at 14.7 (search AlfaBB for AFR guidance) but it likes to run better a little richer. Just my experience with the SPICA I have.
I also found, via my AFR gauge, just by going CW and CCW when the engine stumbles, set it in the middle and it gets really close.
slowcreek likes this.
'76 Alfetta GT, 2013 Fiat 500 Abarth, '78 sports sedan (2 of them) - sold, '91 164L - sold, '83 GTV6 -sold, '87 Milano Verde - sold, '91 spider -sold, '69 MGB GT,
91spiderNV is offline
post #11 of 11 (permalink) Old 09-19-2019, 12:19 PM
91spiderNV's Avatar
Sorry I posted wrong. My AFR at 2500, at best running is about 13.8. Better to be a little rich than lean.
