Dellorto DHLA 40 - Pump jet ball bearing - Alfa Romeo Bulletin Board & Forums
post #1 of 8 (permalink) Old 08-30-2015, 10:22 AM Thread Starter
Che
Che's Avatar
Hello!
I'm new here and I am partly restoring my 2000 GTV Bertone from 1974.
After I overhauled my Dellorto Carbs, I noticed a whistling noise - After that I saw that the Pump jet ball bearing was stuck in the carburetor case.
After I got it out i dried the carburetor case very well and I re-installed the ball, but it was still stuck. I didn't notice any damage on the carburetor case - it's in pretty good shape.
By the way I am referring to part no 51 on the diagram: http://www.gruntled.com/Dellorto/Diagram.html
Has anyone experienced a similar problem? It would be a shame to have to buy a new carburetor because of this.
Thanks in advance and regards from Switzerland,
Che
Che is offline
post #2 of 8 (permalink) Old 08-30-2015, 04:24 PM
rafael's Avatar
Are you sure the whistling noise is not originating from the starter circuit? These trend to make a lot of noise
Spider 2.0i 1992 | GTV 2000 1971 | Giulia Spider 1963
rafael is offline
post #3 of 8 (permalink) Old 08-30-2015, 09:26 PM Thread Starter
Che
Che's Avatar
Hi Rafael, thanks for your reply
I can't exclude that the noise is coming from somewhere else than the carbs but it's the only mechanical parts i changed so far. And the noise let me to realize that the ball bearing was stuck in the carburetor case.
'74 2000 GT Veloce
Che is offline
post #4 of 8 (permalink) Old 08-31-2015, 03:19 PM
rafael's Avatar
Sorry, my post was not clear.
Dellortos have a starter circuit, also called the choke. When enabled this circuit makes lots of noise. The choke or starter is enabled by the starter cable. Disconnect the starter cable from both carbs to make sure that the starter circuit is disabled.
rafael is offline
post #5 of 8 (permalink) Old 09-01-2015, 10:59 PM
quadrifolio's Avatar
Che, your last diagram is from a Weber, not Dellorto
quadrifolio is offline
post #6 of 8 (permalink) Old 09-03-2015, 12:08 AM Thread Starter
Che
Che's Avatar
@rafael
Thank you, I will try it on the weekend.
@quadrifoglio
You are right of course, I just wanted to illustrate the ball bearing in the context of a diagram.
In the meantime, I was able to get my hands on a pair of Dellorto DHLA 40's, so I can replace my old ones. I want to make sure, as the ball bearing regulates the pump delivery valve.
The question remains, how a stuck ball bearing can be fixed. Or let me put it else: If the ball bearing is stuck, should the carb be replaced? I ultrasonic-cleaned the carb twice and the ball bearing was still stuck, so I have to assume that the inner case of the carb has suffered some damage.
Anyway, thanks for the input so far.
'74 2000 GT Veloce
Che is offline
post #7 of 8 (permalink) Old 09-03-2015, 02:15 PM
rafael's Avatar
I do not understand how a stuck ball can make such a noise. If the engine is revving at constant speed, then the accelerator pump is not used.
rafael is offline
post #8 of 8 (permalink) Old 09-14-2015, 02:51 AM Thread Starter
Che
Che's Avatar
For the sake of completeness: The sound was definitely not caused by any damage to the carbs. I exchanged my Dellortos 40s with revised ones. It was then that we found out that the sound was coming from a faulty rubber flange. The damage must have come from the unmounting.
Che
'74 2000 GT Veloce
Che is offline
