159 2.4 mjet black & white smoke - Alfa Romeo Bulletin Board & Forums
post #1 of 1 (permalink) Old 05-15-2014, 04:20 AM Thread Starter
hey guys i really need help with my diesel engine.
the problem start when the car lost power specially when i drive up the hill,i clean the EGR and the throttle body from the carbon and replaced the Boost Sensor. BUT no luck.
then i decide to check the turbocharger, i fit new CHRA.
After that the engine start smoke white (un burn diesel) !!!!
Then i start play with the INJECTORS and end by replace 2 new injectors and write the new code to the ECU.
after that the engine start smoke Black.
Then i play with diesel pump timing to reduce the smoke.because the injector NO 4 value was 5mmi.
after rotate the Diesel pump the value reduced from 5mms to 2.3mmi, but it still smoke white and if i accelerate it smoke lot of black.
i attached the last reading from fiatecuscan.
hope someone can find out what going on
cheers
kimo6 is offline
