DCOE sync issues - Page 3 - Alfa Romeo Bulletin Board & Forums
 5Likes
post #31 of 41 (permalink) Old 07-31-2019, 04:07 PM
classicalfas's Avatar
I used the Permashield and noticed the gaskets split when I tightened everything up. Might make thicker gaskets then use the permashield.
1966 GTA replica, 1967 Duetto, 1987 Quadrifoglio
1972, 1973, 1974 Montreal
classicalfas is offline
post #32 of 41 (permalink) Old 07-31-2019, 04:37 PM
Alfa69GTV1750's Avatar
So, are the rubber mounts necessary?
Mike
1969 GTV 1750
1966 Super
San Diego, CA
Alfa69GTV1750 is offline
post #33 of 41 (permalink) Old 07-31-2019, 05:47 PM
Richard Jemison
Alfar7's Avatar
Hard mounts
I use only hard mounts on my race cars. Alfaholics sells them.
But do not use the rubber o-rings against the carbs, use the thicker paper gaskets (Centerline).
Use a slightly smaller diameter o-ring in the manifold side of the mount. The mount should not be held away from the manifold surface by too thick o-rings.
Ignore the miths that vibration causes fuel mix problems. Just blather perpetrated by word of mouth from the un-knowing.
Gordon Raymond likes this.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #34 of 41 (permalink) Old 07-31-2019, 07:46 PM
Gubi's Avatar
Originally Posted by 930cabman View Post
She started good, seemed to calm down after warming up, but speed still increases with starting fluid introduced and vacuum gauge bouncing
Huh. Well, that's a dilly of a pickle.
Starting fluid is pretty volatile, any chance it's getting sucked into the carb intakes rather than finding leaks? Maybe try liquid spray carb cleaner and see if you get the same results? That's what I use.
I realize I'm reaching here...
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #35 of 41 (permalink) Old 07-31-2019, 09:05 PM
slowcreek's Avatar
You are exactly right. Starting fluid is one of the worst things you can use for that purpose.
Carb cleaner, brake cleaner, windex!!
These^^ will PINPOINT the leak.
Here is starting fluids intended purpose. Aussie version.
Gubi likes this.
It's Giuseppe's giubos, not Guido's guibos, on my 78 Spider and Sport Sedan
slowcreek is online now
post #36 of 41 (permalink) Old 07-31-2019, 09:46 PM
Gubi's Avatar
I...can’t believe that’s a actual product.
The only way that could be more Australian is if Paul Hogan delivered it via kangaroo.
1974 GTV
1991 Spider
Gubi is online now
post #37 of 41 (permalink) Old 07-31-2019, 11:52 PM
I...canít believe thatís a actual product.
Youíre about 30years behind popular culture....
I can see Rebel Wilson (Aussie) selling this, and fixing the car
Craig_m67 is offline
post #38 of 41 (permalink) Old 08-01-2019, 03:58 AM
Thank you all for the support and humor. Brake cleaner sounds like the preferred product.
930cabman is offline
post #39 of 41 (permalink) Old 08-03-2019, 09:54 AM
DrEntropy's Avatar
Windex, or just a spray-bottle with water usually works for me.
DrE--
counting backwards:
'78 Spider (current daily)
'66 1600 GTV (Current Upscale Yard Art)
'69 1750 GTV (my favorite, sold in '80)
'65 1300 GT Junior (my first, parted out in '76)
DrEntropy is offline
post #40 of 41 (permalink) Old 08-03-2019, 10:00 AM
Gordon Raymond's Avatar
Brakeclean is fun because if (when) it happens to ignite, it goes out quickly, but does does give you a nice shot of adrenaline as you hunt for carb air leaks.
Gordon Raymond
Now:
Gordon Raymond is offline
post #41 of 41 (permalink) Old 08-03-2019, 02:57 PM
slowcreek's Avatar
I found out those exact things when spraying for an intake leak on my daughter's Dodge 5.9. Turns out she also had an arcing plug wire at the cap. Boom, adrenaline, flame out, laugh..........trip to parts store.
