Weber tuning with Lambda sensor - Page 4 - Alfa Romeo Bulletin Board & Forums
 6Likes
post #46 of 198 (permalink) Old 08-18-2014, 03:16 PM
ALF750's Avatar
I'd like to get and AFR and test mine. A low idle is better for gear changes I think, much easier to get into 1st at the lights no doubt. That is the drawback of a fast idle.
Past: '81 Giulietta 1.8, 500SL Pantah, 650 Allazurra. Present: '79 Alfetta 2.0, '82 Sportiva II, '91 75TS, Van's RV-4, Giles G-200, Pazmany PL-1. Sunny Australia.
ALF750 is offline
post #47 of 198 (permalink) Old 08-19-2014, 08:57 AM
gigem75's Avatar
This is a great thread! I've got a baseline and will see what changes with the new intake cam I'm installing.
currently
2017 Giulia Q4
74 GTV restored daily driver
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #48 of 198 (permalink) Old 08-21-2014, 02:35 PM
gigem75's Avatar
This is cam timing as it relates to weber tuning so I hope I can put it here. I've superimposed a degree wheel over cam caps superimposed over each other. The timing mark on the right is the intake and left is exhaust. If my scales are right the marks on the caps are several degrees thick. How one would get it exact with them seems impossible to me. The caps are 74 so the marks should be at 102 for the exhaust and 114 for the intake. Using each for a starting point I've put red and green lines where I think 104 should be. Am I close? Do I need to move them, if so which way? Thanks maybe this will help others check against the templates.
currently
2017 Giulia Q4
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #49 of 198 (permalink) Old 08-21-2014, 03:39 PM
Trained (ex)Professional
1953-2018 RIP
papajam's Avatar
One must keep in mind that the 102, 104, 114, etc cam timing numbers (a format not used by Alfa, BTW) refer to degrees of crankshaft rotation, not the cams. For example, timing an intake cam to 114 means that the intake valve will be at maximum lift when the piston is at 114 degrees After Top Dead Center (ATDC); an exhaust cam at 102 means the exhaust valve will have max lift at 102 degree Before Top Dead Center (BTDC). Since the cams turn at one half crankshaft speed, one needs to calculate this into the equation.
Conveniently enough, a straight up vertical line on the cam cap is 100 degrees (or zero on your degree wheel). A mark on the cap one degree to the right of vertical equals TWO degrees of crankshaft rotation. This results in a cam timing of 102 (1 x 2 + 100 = 102). To time the intake cam to 104, your mark needs to be two degrees right of vertical (2 x 2 + 100 = 104). Same formula applies to the exhaust cam; for a 104 cam timing, the mark on the cap needs to be 2 degrees left of vertical.
Take note of where the factory marks on the caps are; 7 on intake and 1 on exhaust. This equates to 114 and 102 respectively.
papajam is offline
post #50 of 198 (permalink) Old 08-21-2014, 04:19 PM
gigem75's Avatar
Thank you! !00 straight up really helps and I was pretty sure about the ratio but for sure is way better than pretty sure The marks being as wide as they are sure isn't exact but short of taking the motor out and setting up a degree wheel they will have to do. At least I did check TDC against the pointer when it was on the engine stand.
currently
2017 Giulia Q4
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #51 of 198 (permalink) Old 08-22-2014, 04:44 AM
1953-2018 RIP
papajam's Avatar
Originally Posted by gigem75 View Post
The marks being as wide as they are sure isn't exact...
For a street engine, a degree or two either way would be, IMO, extremely difficult for most drivers to even tell the difference. IOW, ballpark close is good enough. Using a degree wheel will get you in the right section while adjusting the lash of each valve so the valves are all timed the same puts you in the correct seat.
papajam is offline
post #52 of 198 (permalink) Old 08-22-2014, 05:09 AM
I once spent some time playing with LC's in my prevoius motor and I agree that it is hard to tell the difference. I did stop watch runs on a section of road to make comparisons. It think that I could do it better now as the Zeitronix records time as well as rpm and AFR. So if I did WOT runs on exactly the same stretch of road under similar weather conditions then I should be able to measure accurately the acceleration.
2011 Jaguar XKR
alfaparticle is offline
post #53 of 198 (permalink) Old 08-22-2014, 05:34 AM
gigem75's Avatar
Speaking of weather and tuning here in the afternoon making a run is like trying to get a Cessna 150 off the ground with two heavy people in the cockpit with full tanks, on a 100 degree day. The difference in the way my motor runs between the early morning and 98 degree high humidity afternoons is quite noticable. On idle jets which would be considered leaner than a 45 F9. a 45 F8, or a 40 F9? I'm assuming a 45 is leaner than a 50, right?
currently
2017 Giulia Q4
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #54 of 198 (permalink) Old 08-22-2014, 06:22 AM
1953-2018 RIP
papajam's Avatar
A 45 has a smaller fuel orifice than a 50 but that does not necessarily make it leaner (the two digit number is the diameter of the orifice; a 45 is 0.45mm, 50 is 0.50mm, etc). The other part of the equation is the 'f' number. This designates the number of and the diameter of the air bleeds. Thing is, the f numbers are not in any particular order according to size so one needs to look at a chart of Weber idle jets.
papajam is offline
post #55 of 198 (permalink) Old 08-22-2014, 07:15 AM
40 is very small for your motor. Des Hammill makes the following recommendations for fuel orifices
40 - 250 to 350 cc/cylinder
45 - 350 to 420 cc/cylinder
50 - 420 to 490 cc/cylinder
55 - 490 to 560 cc/cylinder
Alfa fitted 50F8 in 2L motors and that should be close, even with bigger cams.
50F11 is one step leaner and 50F9 is one step richer. I would be surprised if you had to go outside of that range.
Here is a copy of the Weber tuning manual. http://www.lainefamily.com/images/WeberTuningManual.pdf
You will find dimensioned drawings of all idle jets. It may be possible to drill out an orifice to make a different idle jet if you do not have it on hand.
the list of idle jet air bleed suffixes from rich to lean is F6, F12, F9, F8, F11, F13, F2, F4, F5, F7, F1, F3
Craig_m67 likes this.
2011 Jaguar XKR
post #56 of 198 (permalink) Old 08-22-2014, 08:37 AM
gigem75's Avatar
Thanks! My webs came with 45 f9 and I put 45 f8's in which is what I have now. I did see where the 2L euro motors came with 50 f8. I guess what I was asking was is moving from 50 to 45 give the same amount of lean condition as going from f9 to f8?
I've got a set of 50 f8's comming just to see what they do. It would be richer than a 45 f8 or 9? For 15 bucks and free shipping it's cheap at twice the price, maybe.
currently
2017 Giulia Q4
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #57 of 198 (permalink) Old 08-22-2014, 09:02 AM
At idle or on the first progression hole 45F9 may be a lot like 50F8 but 50F8 will supply more air/fuel emulsion at the top of the progression range and that will influence the transition.
2011 Jaguar XKR
post #58 of 198 (permalink) Old 08-22-2014, 09:58 AM
A very useful like that decodes the jet nomenclature:
http://www.paulspruell.com/motorspor...ting_chart.jpg
The home page can be found here:
Alfa Engines and Parts
Jason
'79 Spider
ljayr is offline
post #59 of 198 (permalink) Old 08-22-2014, 11:30 AM
gigem75's Avatar
To see how the F numbers relate to mixture really helps understand whats going on. We're getting there slow but sure, thanks!
currently
2017 Giulia Q4
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #60 of 198 (permalink) Old 08-25-2014, 08:14 AM
gigem75's Avatar
4th gear at a 3700 cruise was giving me right around 13.2 afr and the motor sounded happy. I thought I had a 6500 rev limiter plug in the msd which led me to believe my tach was way off but it turns out it was a 7000 plug. I ordered a couple of 6500 plugs from msd for three fifty each and put one in. What I need to do now is a good run at speed and look at the plugs. Now that i have the cams timed as close to 104 as i can get I'd really like to log with rpm and add vacuum in there as well.
currently
2017 Giulia Q4
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
