Weber tuning with Lambda sensor - Page 13 - Alfa Romeo Bulletin Board & Forums
 5Likes
post #181 of 188 (permalink) Old 09-10-2019, 09:48 AM
Ed - thanks for the reply. If I take the ZT2 ground back to the battery, is that considered a good ground (from an electronics perspective)? i.e. is this likely to eliminate potential ground loops? regards
FlyingBanana is offline
post #182 of 188 (permalink) Old 09-10-2019, 09:56 AM
The signal from coil -ve is with reference to the engine because the distributor body is the ground. So in theory a connection to the block or front cover is best.
2011 Jaguar XKR
alfaparticle is offline
post #183 of 188 (permalink) Old 09-10-2019, 10:02 AM
Mike,
I looked at the Weber drawings for emulsion tubes and F16 and F11 are almost identical except that F11 has 4 extra high holes which I think are intended to lean the mixture a little at high rpm.
John Passini wrote that nearly all Ford engines with DCOE's use either F16 or F11. F16 being the choice for full blown race engines and F11 for "less hairy" motors.
In my case it is mid range richness that I would like to lessen when the top end is tuned for 12.8 to 13.2
2011 Jaguar XKR
post #184 of 188 (permalink) Old 09-10-2019, 05:16 PM
gigem75's Avatar
Ed, I have a set of F9s. If I remember correctly I had them in but changed to the F11s because a sputter or bumble at steady rpms without any load. It was so long ago before I had the wide band. It's a totally different motor now and since I have the wide band it can't hurt to drop some F9s in to see what happens.
When I pulled the plugs to do the compression check the insulators were white white but with no deposits and the outer base was black. I'd like to see a light chocolate brown on the insulators and base.
currently
2017 Giulia Q4
74 GTV restored daily driver
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #185 of 188 (permalink) Old 09-10-2019, 06:08 PM
F9's did not work well for me either. The top went lean and I could not get it back with smaller air correctors and I had to go up on main jets which made it too rich in the mid range and at part throttle.
2011 Jaguar XKR
post #186 of 188 (permalink) Old 09-11-2019, 01:31 PM
Interface circuit
I built another of the little interface circuits today and played around with it on the bench. The capacitor should be 10 nF and the resistors should be 22K for best results. I hooked it up to the coil -ve and I got a pretty clean rpm trace up to 7000 rpm.
2011 Jaguar XKR
post #187 of 188 (permalink) Old 09-11-2019, 03:54 PM
65Sprint's Avatar
Ed, did the new interface clean up the tach signal compared to what you had? We can still swap ZT-2s sometime.
Rich Hanning
65Sprint is offline
post #188 of 188 (permalink) Old 09-11-2019, 05:42 PM
Yes, it cleaned it up and therefore I should not need to swap ZT2's.
Not sure what did the trick, changing component values or running a good ground from the bar on the rear of the cam cover to the ground point for the ZT2, or a bit of both.
2011 Jaguar XKR
