Car restorations for the rest of us.... - Page 3 - Alfa Romeo Bulletin Board & Forums
post #31 of 52 (permalink) Old 11-10-2008, 04:06 PM
Weaving a Spider's Web.
brownie93's Avatar
Nice and clean Looking good.
77 Spider-rust issues-but fun! SOLD
93 Spider-151k km-SOLD
94 Spider CE- 48k miles
2012-MB SLK350-45k km
Joyce
brownie93 is offline
post #32 of 52 (permalink) Old 11-10-2008, 09:08 PM
gigem75's Avatar
Good work there UW!
gigem75 is offline
post #33 of 52 (permalink) Old 11-22-2008, 02:47 PM Thread Starter
Ok, this week we're playing with the wiring. Trying to get all the lights to work.
This box makes noises as soon as I connect the battery. What is it? The flasher relay?
Here's some extra bonus electrical bits installed by the PO. The black box is a high tech quartz digital clock! The other thing is... looks like two capacitors wired together. Not sure.
UngaWunga is offline
post #34 of 52 (permalink) Old 11-23-2008, 11:14 AM Thread Starter
Think I found a $10 direct replacement for the flasher relay. Its a 4 pole flasher relay with 49/49a/31/C2 markings on it, with the stock one having 49/49a/31/KBL. Made by Tridon.
post #35 of 52 (permalink) Old 11-23-2008, 05:30 PM
gigem75's Avatar
keep us posted!
gigem75 is offline
post #36 of 52 (permalink) Old 11-25-2008, 10:17 AM
if the two red things labeled like 1000mF or uF or some similar , yes it will be capacitors. If not, I guess they are old NiCad batteries, probably for an instrument's inside memory, perhaps for the quartz showed clock. Get of all of these things!
vangelislaz is offline
post #37 of 52 (permalink) Old 11-25-2008, 11:49 AM Thread Starter
Oh I did. I'm tracking down a problem where a blow a fuse everytime I turn on the parking lights. Those two things were soldered to the fuse block, so I snipped them off. There's an electric tach mounted on the dash, and that's still soldered to the fuse block in a ungainly manner. I'll wire that up appropriately once I figure out what's trying to let all the smoke out of the wires.
post #38 of 52 (permalink) Old 11-25-2008, 03:08 PM
seems you have a trouble there. To figure out what is going on I suggest to de-wire anything not original-stock and then I guess you can simply follow the proper diagram to see and solve the problem. Any photo of the mess?
post #39 of 52 (permalink) Old 04-05-2009, 04:07 PM Thread Starter
So, I'm back. And back into the wiring. Now, on to this mess...
It looks like xmas tree light wiring was used to connect the switches.. Awesome.
post #40 of 52 (permalink) Old 04-05-2009, 07:16 PM
Floor looks pretty darn solid - you might have a keeper. But that's some wacky wiring there to be sure. Might want to just yank the whole harness out and start fresh. I think complete harnesses are available fairly reasonable.
Good luck!
gprocket is offline
post #41 of 52 (permalink) Old 04-05-2009, 07:31 PM
gigem75's Avatar
I saw that floor and my first thought was I should be so lucky! I wish
Did the flasher work?
gigem75 is offline
post #42 of 52 (permalink) Old 04-07-2009, 01:37 PM Thread Starter
Yeah, I really don't have much to complain about. There is some rust to the rockers, but everything else is in ok shape.
The flasher? Not sure. It did once when I was wiggling wires around. Other times it flashed like crazy and wouldn't shut off no matter where I moved the TS stalk.
More things to clean up...
Good thing I don't depend on this as a daily driver!
post #43 of 52 (permalink) Old 04-13-2009, 08:57 PM
PSk
Suggest you get some rust protection into this car asap, looks like a nice find ... and then yes you might be able to continue this form of restoration.
Best of luck
'71 1750 Series 2 GTV:
PSk is online now
post #44 of 52 (permalink) Old 02-25-2012, 09:22 AM
LemansGT's Avatar
I've recently purchased this car from ungawunga and look forward to getting it back on the road!
LemansGT is offline
post #45 of 52 (permalink) Old 02-26-2012, 05:22 AM
jcslocum's Avatar
Good luck!!!
Where are you located??
Jon '74 GTV RIP Tifosi
jcslocum is offline
