67 Duetto 663438 Restoration - Page 9 - Alfa Romeo Bulletin Board & Forums
 33Likes
post #121 of 150 (permalink) Old 12-18-2018, 10:13 PM Thread Starter
velocewhippet's Avatar
I put a thin coat of satin black on the body. Careful, not to fill in the original crinkle paint texture.
The internal parts cleaned up easily with navel jelly.
ossodiseppia likes this.
velocewhippet is offline
post #122 of 150 (permalink) Old 02-02-2019, 03:06 PM Thread Starter
Fabricating the missing Chassis Bump Stop
I gave up trying to find a replacement for the missing bump stop on the right side of the chassis.
Here's the part: Made from a combination of 1.5" tubing, and flat sheet metal. Forming a cone wasn't easy.
I took dimensions off the part on the left side. As you can see, there wasn't any bump stop on the right side.
post #123 of 150 (permalink) Old 02-02-2019, 03:13 PM Thread Starter
I used a short length of all-thread to hold it in place. I don't know why those holes needed to be there, but on the left side they line up vertically and so I used them.
PSk and Craig_m67 like this.
post #124 of 150 (permalink) Old 02-02-2019, 04:35 PM
USTA BE AN AD-MIN
ossodiseppia's Avatar
Great job.
ossodiseppia is offline
post #125 of 150 (permalink) Old 02-02-2019, 09:00 PM
Nicely done
stphers is offline
post #126 of 150 (permalink) Old 02-03-2019, 05:02 AM
grapppa's Avatar
Velocewhippet,
This version of the vent controls has a detent "click" and the end of the range - correct? The version I had in my 68 car did not have this feature and was significantly more flimsy...
grapppa is offline
post #127 of 150 (permalink) Old 02-03-2019, 05:42 AM Thread Starter
Originally Posted by grapppa View Post
Velocewhippet,
Yes, the version that I'm using (the one that came out of a 66 Duetto) has a definite "click" at both ends of the controller travel.
I prefer that one over the later design.
However, after my initial writeup of the later design, I did go back and inspected my 67 controller again. It looks like it does have an isolation plate between the 2 levers that should keep the adjustment of one lever from effecting the position of the other lever. But because of flexing of the sheet metal, the isolation plate wasn't anchored properly. So, it ended up not isolating the 2 levers from each other. That said, there still isn't any feature in the later design that would provide any tactile feel when you adjust the levers to the end of their range. So, I still think the early design operates better.
grapppa likes this.
post #128 of 150 (permalink) Old 02-04-2019, 06:12 AM
SUBSCRIBED:
What an awesome story. Can't wait to see you finish your beautiful Duetto. Keep up the good work!
1967 Alfa Romeo Giulia Sprint GT Veloce
1970 Alfa Romeo Giulia Sprint GT Junior
Doraiba is offline
post #129 of 150 (permalink) Old 03-12-2019, 06:25 PM Thread Starter
So, I'm trying to get a correct Carpet set put together and I've read that the Hand Brake Boot was sewn onto the Carpet.
I've got 2 original Carpet sets and I can't see where the Boot was sewn onto it. Should I have the Boot sewn to the new Carpet?
These first 2 pictures are the underside of the original Carpets.
post #130 of 150 (permalink) Old 04-14-2019, 07:35 PM
arswaim's Avatar
Would you mind sharing the dimensions of the bump stop if you still have them? I’m about to try to fabricate a replacement for the missing right hand one on my Duetto and don’t quite trust the measurements I’ve taken from the left side.
Alex
1966 Duetto 1600
arswaim is offline
post #131 of 150 (permalink) Old 04-14-2019, 10:22 PM Thread Starter
Originally Posted by arswaim View Post
Would you mind sharing the dimensions of the bump stop if you still have them? Iím about to try to fabricate a replacement for the missing right hand one on my Duetto and donít quite trust the measurements Iíve taken from the left side.
Alex
No problem.
This is the quick sketch I put together when I measured the one remaining bump stop I had.
I didn't include the dimension of the flange at the top, but it was probably about 5 inches in diameter.
Don't make the diameter of the cone any larger than 3.75 inches at the top. Otherwise the spring seat won't fit.
Jeff
VeloceRosso likes this.
post #132 of 150 (permalink) Old 04-15-2019, 03:35 AM
arswaim's Avatar
Greatóthanks very much! Iíll let you know how it turns out.
Originally Posted by velocewhippet View Post
No problem.
Jeff
1966 Duetto 1600
arswaim is offline
post #133 of 150 (permalink) Old 06-14-2019, 04:59 PM Thread Starter
Centro Documentazione
Received this today from Alfa. Not a lot of information. I wonder if the Market destination is always the port of entry?
post #134 of 150 (permalink) Old 06-15-2019, 05:06 AM
GTD
GTD's Avatar
Wes
By 1967 AR had established their corporate headquarters (USA) at Johnson Avenue, Newark, NJ hence all East Coast delivery was via the Port of Newark, NJ.
This was prior to moving to Englewood Cliffs, NJ in 1969.
Records of distribution to dealers, then to actual buyers would have been discarded long ago.
Here's a link to a great write up of a Duetto Love Story: https://www.slideshare.net/mausala58...nch-in-the-70s
Alfa Sapiens
GTD is offline
post #135 of 150 (permalink) Old 07-23-2019, 05:24 PM Thread Starter
Some updates to report on...
Used parts from my 4 seats (2 from 663438, 2 from a 1968 1750 spider) to make the best pair of seats.
Upholstery and seat foam came from Classic Alfa.
PSk, Craig_m67 and Alfamallorca like this.
