-   Car Restoration (https://www.alfabb.com/bb/forums/car-restoration/)
-   -   staring resoration 73 GTV gauge cluster (https://www.alfabb.com/bb/forums/car-restoration/4364-staring-resoration-73-gtv-gauge-cluster.html)
Kjell 03-01-2004 12:23 PM
starting resoration 73 GTV gauge cluster
1 Attachment(s)
My 73' GTV is in great shape, however the gauges are a little "murky" and the
back of the housing is distorted (too
much heat?). The dash is perfect so
I decided to try to find a nice gauge
housing to swap. Found a straight
cluster and started to restore the
plastic lenses. Here's a before shot
Kjell 03-01-2004 12:25 PM
1 Attachment(s)
the lenses had some scratches, so I used
some Novus plastic polish and they cleaned up nicely
Kjell 03-01-2004 12:26 PM
1 Attachment(s)
Here's the plastic polish, works great on
any plastic!
Kjell 03-01-2004 12:27 PM
1 Attachment(s)
Next step restore housing.....
Sniady 03-01-2004 07:15 PM
Kjell just does everything the right way. Look's good, as everything else you do.
alvin moreno 03-01-2004 07:34 PM
Kjell, nice job. I plan on doing the same with mine. Were would I find the plastic polish.
Alvin.
Kjell 03-02-2004 08:13 AM
Hi Alvin, don't recall source but a search
on e-bay will get you lots of options.......
Kjell
Kjell 03-24-2004 08:28 AM
finished
1 Attachment(s)
OK ,finally got around to finishing. Here's a before pic of the cluster.
Kjell 03-24-2004 08:30 AM
1 Attachment(s)
here's the finished product, much clearer. Now I should be able to see them at
night.
GTV4EVR 03-24-2004 08:38 AM
How is the plastic in front of the speedo and tach attached? The PO seems to have glued it in and the glue has discoloured. I'm assuming I need to use brute force to remove it, but I figured I would check first.
Kjell 03-24-2004 08:45 AM
Hi Ken, they where originally attached by plastic pins, the ends of which were
melted to hold them in place. I ground off the ends with a dremel tool then
glued them when I put it back together. These gauges sure are some real cheap
sh*t, aren't they? Really out of character with the rest of the car.........
GTV4EVR 03-24-2004 08:47 AM
Thanks Kjell!
