need advice from the pros - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 02-02-2004, 07:29 PM Thread Starter
wctouring#7's Avatar
Question need advice from the pros
Just picked up a GTV (another one :-) today, its a solid car except for the base of the front windshield. What are my options? Do I need to find a donor car to cut the pieces from or are there patch panels avialable for this area? Thanks.
wctouring#7 is offline
post #2 of 6 (permalink) Old 02-02-2004, 08:02 PM
Roadtrip's Avatar
I'm no pro, but here's a link to a web site that did exactly what you're planning to do. http://www.alfarestore.com/ Great site and great pictures. I'd say that rust is the tip of the iceberg and I think you're going to have to fabricate part of the windshield channel by hand. Probably a bunch more once you get that fender off.
Congrats on the GTV. It's not fair that you should have two. You should give me one!
John Stewart
74 Spider
91 164S
Roadtrip is offline
post #3 of 6 (permalink) Old 02-02-2004, 10:19 PM
Roadtrip is right I had a 50 cent size rust hole in the same place your rust is and when I pulled out the windshild the whole bottom lip the windshild sits on was gone I could hardly believe it, I knew it was going to be bad with water leaking thew to my fuse box but I was not ready for that.
72 berlina
87 milano
97 Lotus Elise
Lifer is offline
post #4 of 6 (permalink) Old 02-03-2004, 05:50 AM Thread Starter
Thanks for the replys, actually the first GTV I got was one I picked up locally for a friend who lives out of the area....its going to its new home this weekend. The red one is for me. Luckily there is no water/moisture damage inside due the the rust. I figured I would probably have to fabricate pieces from scratch to replaced the rusted area, unless I can find a donor car to cut them off of. I just wanted to make sure there were not patch panles available.
___________
Greg
post #5 of 6 (permalink) Old 02-03-2004, 06:43 AM
Roadtrip's Avatar
Well, we can hope for the best. Isn't there a saying somewhere?
.........an Alfa is like a box of chocolates . . . . well, you know the rest.
John Stewart
74 Spider
91 164S
Roadtrip is offline
post #6 of 6 (permalink) Old 02-03-2004, 07:19 AM
Trained (ex)Professional
1953-2018 RIP
papajam's Avatar
I understand, perhaps incorrectly, that rusting around the windscreen is more of a problem with the glued in windshields than with the gasketed type. As many have done, you might want to consider retrofitting a 1750 or earlier gasket type windshield and gasket. It's not the cheapest mod though. The gasket type windshield is a little smaller so you can't just put a gasket on your current windshield. You need a different windshield. And the trim to go with the gasket although I've heard that some folks leave the trim off.
papajam is offline
