Bob's Barn Alfa - Page 13 - Alfa Romeo Bulletin Board & Forums
 89Likes
post #181 of 425 (permalink) Old 08-11-2015, 03:44 PM Thread Starter
horsewidower's Avatar
Gigem, yep...I'm just being cheap.
Our experience with poly on the racecars has not been great. We go directly to heim (rose) joints.
I'd like to keep my teeth, so I won't be going there with a road car.
But wait there's more: View my 164LS thread:
You didn't...oh yes I did II. 1995 164LS 5 speed, awesome when it runs!!!
Musings on shop related items:
horsewidower is offline
post #182 of 425 (permalink) Old 08-12-2015, 12:34 AM
PSk
Originally Posted by horsewidower View Post
Given the known issues with the FRAP upper control arm bushing, does anyone have experience with Poly in that location? I have that on hand; if its a decent substitute it'll save me the expense of another set of lower bushes to be used in the upper...yep sounds confusing.
Bob
Poly is [email protected]
It goes like this: Poly < Rubber < Rose/Sperical joints
'71 1750 Series 2 GTV:
PSk is offline
post #183 of 425 (permalink) Old 08-12-2015, 07:08 AM
65Sprint's Avatar
I have had polyurethane bushings from IAP in the upper control arms of the '88 Spider for about two and a half years and 15,000 miles. No issues at all. This car is essentially stock and driven to work at least twice a week, 60 miles round trip. Prudent use of poly suspension bushings makes sense.
Rich Hanning
65Sprint is offline
post #184 of 425 (permalink) Old 08-12-2015, 09:28 AM
[quote]
I'm assuming you're using adjustable upper control arms? There is some evidence that FRAP may have improved their bushes but The Received Wisdom suggests that using lower control arm bushes in inner upper control arm position work well. They fit and do work well. But they're expensive. Even with librication, poly bushes will at some point start making noise as lube goes away and getting new lube to them would be a problem. A friend looked askance when I asked about this and simply asked if I'd ever had trouble with the oem style inner control arm bushings? Not in 10's of thousands of miles over many years . . . That pretty much answered my question for me. Only problem was that nobody had the oem style bushes last summer. As luck would have it, I found a pair of oem bushes that I'd apparently had for a couple of decades at least. So, upon my friend Bob's-who-knows-all-things recommendation I went with poly bushes in the castor arm position and oem bushes at the inner control arm position. In my opinion, you can use the expensive lower control arm bushes but the stock oem bushes work very well and are a lot cheaper. Just sayin'.
180OUT is offline
post #185 of 425 (permalink) Old 08-12-2015, 09:48 AM Thread Starter
Thank you all for your replies.
The FRAP arms I have are adjustable. They are brand new...12 year old purchases. So, probably not benefiting from any upgrades done recently.
post #186 of 425 (permalink) Old 08-12-2015, 09:48 AM
Subtle's Avatar
I'll intrude with thanks for the recent posts on bushings.
My winter project for "Supah" is to have all of the bushings changed to new.
Will do the standard ones.
Would like less road noise over rough surfaces.
Bob,
Subtle is offline
post #187 of 425 (permalink) Old 08-12-2015, 10:05 AM Thread Starter
LOL, you are clearly ahead of me. At this point, after 12 years of ownership, I'd like some noise over any surface...I've never driven the car except to steer it while its being towed around the place behind a tractor.
post #188 of 425 (permalink) Old 08-12-2015, 10:07 AM
I should add that the FRAP adjustable upper arms have a dimensional difference from the stock arm in the castor-arm bushing position. Paul Spruell's site mentions this difference so, before buying replacement bushings. I'd recommend reading his information. Bob-who-knows-all-things-Alfa suggested that I use poly bushings (the only place he recommends, btw) in the castor arm position because it is apparently a high stress point. I ordered Spruell's poly castor-arm bushes (he had a good price) and installed them myself. Use lots of lube and a good vice with a big socket and they'll go right in. They're actually easier to put in than the stock bushings. The combination of oem inner arm and poly outer arm bushings work well. Everything fits and I have confidence that the inner arm bushings aren't going to fail.
180OUT is offline
post #189 of 425 (permalink) Old 08-12-2015, 10:19 AM
Subtle's Avatar
LOL
I used to think that poly bushes made noise when dry.
Then slowly realized that the original ones would be designed to reduce road noise.
I was spoiled with the 101 Spider--it virtually had fresh everything in it. Quiet and smooth--nice ride with the 80 ratio tires,
Bob,
Subtle is offline
post #190 of 425 (permalink) Old 08-12-2015, 10:21 AM
Push hard and live
DPeterson3's Avatar
When I redid the suspension on my Montreal, the original inner upper bushings had walked out of the arms, shifting the arms to one side, causing them to rub on the steel pocket side. Perhaps the heavier engine was a factor? I replaced these bushings (and the caster rod bushings) with poly. No complaints so far, but the real test is likely to be over more miles than I'll drive it.
horsewidower likes this.
Don P
Carson City, NV
Past Alfas...
Current Alfas
Oops. Add to the "present" list, 10204 01488, 2000 Touring Roadster project
And past...
1946 Luscombe 8A
And present...
64 Mooney M20E ("Rambo". My faithful steed for over 40 years) Over 55 years old, and just returned from a trip to Argentina in him
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is offline
post #191 of 425 (permalink) Old 08-12-2015, 07:05 PM
Ranz's Avatar
Yeah, but if you make engine noises with your mouth, it feels much better....
Ranz is offline
post #192 of 425 (permalink) Old 08-12-2015, 07:33 PM Thread Starter
Ha!
Going out to the workshop to give that a try right now.
post #193 of 425 (permalink) Old 08-13-2015, 12:36 PM Thread Starter
Purchased a small order from PMB for the caliper "O" rings. $16+ including shipping and handling for 12.
Purchased everything else, except the master clutch cylinder and brake reservoir, from Classic Alfa. Added in a trunk (boot) medallion. Came in at about $200 including $37 for shipping. I hope it all gets here before the last week of the month. Someone might ask, "why Classic Alfa?" They had all the small hardware I needed, and the pricing for some of the more expensive items was 40% less. I also prefer to buy from one vendor, generally, so I only have one vendor that I have to chase around.
But in the end, it was about getting all the small stuff.
Everything else I've purchased for the car has come from Centerline, IAP, APE and Jon Norman.
post #194 of 425 (permalink) Old 08-13-2015, 01:28 PM
95% of my stuff has come from Classic Alfa. They are great. Often faster then getting it in the USA. I just try to make big orders to save on shipping...but not always convenient when you think you need that one last part to finish a task.
mb230s is offline
post #195 of 425 (permalink) Old 08-15-2015, 06:58 PM Thread Starter
I had a bit of a hiccup with Classic Alfa, the bank thought it was a fraudulent transaction. With 2 minutes to COB in the UK, we were able to get it cleared up and things shipped Friday. Made by "this much." !!
Finally defeated the evil clutch slave cylinder. Much cleaning fluids, anti-corrosion fluids, curse words and disturbed greasy crap was expended in the effort. A win a day, that's all I ask.
Bob
Tags
1974, 2000, gtv
