1974 GT 1300 Junior restoration (Denmark) - Page 5 - Alfa Romeo Bulletin Board & Forums
 10Likes
post #61 of 85 (permalink) Old 01-25-2015, 12:44 PM
Looks good. How do you plan to prevent rust in the future ?
Lani is offline
post #62 of 85 (permalink) Old 01-25-2015, 01:06 PM Thread Starter
kitora's Avatar
First it needs to be sand blasted, and then painted. However I am not sure yet which type of paint to use. I need to investigate that some more.
1974 Alfa GT1300Junior
kitora is offline
post #63 of 85 (permalink) Old 01-26-2015, 12:14 AM
After sandblasting, I would consider thermal metallization if I were you. Jyderup Sandblæseri can do both for you.
Lani is offline
post #64 of 85 (permalink) Old 01-28-2015, 11:20 PM Thread Starter
kitora's Avatar
First of all, they are too far away for me to make them a realistic choise, and second of all, I beleive it is a waste of money. I am fully aware that the metal is better protected, but my car will be in a garage, and only be used a few times every year during summertime, so it is unlikely it will ever even see rain again. I am confident that a thick layer of epoxy primer after the sand blasting will seal off the metal from the enviroment just fine. All cavities will be filled with cavity wax once the car has been painted, and using the rotisory I can make sure it reaches every corner where it needs to go.
kitora is offline
post #65 of 85 (permalink) Old 01-29-2015, 07:01 AM
ok, that is also a good solution. Do you plan to drill holes for the injection hose before the epoxy paint ? and do you plan to use rubber plugs for the holes afterwards or do you have another solution ?
While unable to sleep sometimes I think a lot of getting a project like yours. I think a lot of how to prevent rust the best way in the future. Some times I think Im about to loose my mind about it.
I have a theory that the blue/black/brownish discoloring on the backside of weldings are good starting points for rust. So I was thinking that after one had welded, like lets say a patch, and there is a cavety behind it where the backside of the weld is exposed. Perhabs one could sandblast the discoloring via a hose and then vacume out the sand particles. Then spray epoxy inside the cavity and at last spray cavity wax in there.....hmmmm maybe I think too much
Lani is offline
post #66 of 85 (permalink) Old 01-29-2015, 03:41 PM
1750GT's Avatar
Don't know how I missed this thread completely....but having just gone through it all....I must say you've really tackled a challenging restoration! Gotta give you kudos though...you've done a lot in the short time of what 2 years or so? Very nice!
1750GT is offline
post #67 of 85 (permalink) Old 01-29-2015, 04:08 PM
gigem75's Avatar
Really nice!
currently
2017 Giulia Q4
74 GTV restored daily driver
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #68 of 85 (permalink) Old 02-07-2015, 11:38 AM Thread Starter
kitora's Avatar
I got to spend a it more time working on the car today. I have reached a major milestone as the last body panels have been welded in. The transverse chassis frame pieces were the last 2 pieces missing. Even though the car is now basically complete I still need to do a lot of welding grinding and adjustments to do before the car is ready for sand blasing and paint.
kitora is offline
post #69 of 85 (permalink) Old 08-11-2015, 07:58 AM Thread Starter
kitora's Avatar
Updating the thread is slow, but progress on the car is equally slow, so I guess it's OK then...
Over the summer I have spent a little bit of time on the car. Even though all metal work is "done" there are still a lot of welds to be completed and grinded down. Also all gaps needs to done in preparation for paint. That is very time consuming, but I know I will regret if I don't spend the time now.
I have bought parts for a GTA grill conversion, and modified the front apron accordingly. I have chosen to find a compromise between bumper and bumperless, as I don't like either too well. I have cut the middle section of the front bumper out. However I want to cut them down a bit more and move them closer to the body of the car. That is a future project.
Also I have installed the GTA door handles. More to follow within a couple of months...
kitora is offline
post #70 of 85 (permalink) Old 08-11-2015, 10:56 AM
PSk
Nice work!
I personally don't understand the GTA grill conversion on the 4 headlight front ... IMO the 1750 grill looks considerably better/best and would be what I'd convert it to.
It is a pity Alfa didn't move to the GTA style door handles for all models as a better door handle I think
'71 1750 Series 2 GTV:
PSk is offline
post #71 of 85 (permalink) Old 08-12-2015, 11:10 AM Thread Starter
kitora's Avatar
PSK: That's a matter of taste. I like the GTA grill a lot, so that's what I have chosen. IMO it looks more modern than the 1750 grill, which I think looks a bit older.
I know my car is not a GTA, but I like the semi-racing styled cars better than the street car look. The GTA decals are also in consideration, but there's a long way to go before getting to that point.
I appreciate all the comments to the thread. It is encouraging to read the constructive feedback.
kitora is offline
post #72 of 85 (permalink) Old 11-27-2015, 12:42 AM Thread Starter
kitora's Avatar
Time for another update. I finalized the rust repairs, and the very last piece was the bottom of one of the doors.
After doing rust repairs I thought I would fit the door seals and confirm that the doors would still close. They wouldn't! Not even close to being able to! That was making me panick, but a new set of seals solved the problem. Now the doors close and lign up perfectly.
Test fitted all glas, and everything fits perfectly.
I had the interior, trunk, engine compartment and bottom of the car sandblasted and epoxy primed. I cleaned the car off after the sandblasting. There was sand EVERYWHERE!! It took me 4 full hours of air preassure blowing to get the car free of all sand. Even though it is not a very interesting task, at least it feels good knowing that sufficient effort has been put into cleaning out all remains of sand.
It's great to finally reaching "bottom" of the restore, and seing that things are heading towards assembly.
rz133 and JCDK like this.
kitora is offline
post #73 of 85 (permalink) Old 01-18-2016, 11:35 AM Thread Starter
kitora's Avatar
After the car was sand blasted it was painted with an epoxy primer containing zink for extra protection. I brough the car back home where I used filler to smooth out the areas that needed it, and also used seam sealer for all seams.
After this I covered the bottom, the wheel whels, the interior and the trunk with Upol Raptor bedliner. I used 2 kits of it, so a total of 8 liters.
The car has now been dropped off at the painter, so the exterior can get a coat of primer, and everything else the final red paint on top of the bedliner. Once that is done, I get the car back, so I can mount the suspension prior to exterior paint.
Also all suspension components have been sand blasted and painted with 2 layers of primer and 2 layers of paint, and I can now start assembling these parts while waiting for the shell from the painter.
kitora is offline
post #74 of 85 (permalink) Old 01-18-2016, 12:23 PM
That must feel so good!
Now the fun begins..
JCDK is online now
post #75 of 85 (permalink) Old 01-18-2016, 11:51 PM Thread Starter
kitora's Avatar
It feels fantastic. I am super excited.
JCDK likes this.
kitora is offline
