rotisserie build - Page 4 - Alfa Romeo Bulletin Board & Forums
 1Likes
post #46 of 50 (permalink) Old 04-27-2011, 04:54 AM
GTD
GTD's Avatar
Et all ... show me.
Alfa Sapiens
GTD is online now
post #47 of 50 (permalink) Old 04-27-2011, 07:00 AM Thread Starter
lotuseleven's Avatar
From the toolman web site (he's the guy who posted the plan).
Restoration Log: January 12, 2005
that's a pretty big buick he has on his rotisserie. He had clearance issues as shadetree suggested, but I suspect his car is a bit wider than mine. I did get the measurement to ground wrong. I'll measure it and post the actual clearance. Proof is in the putting (or is it pudding?). Give me a month and I'll have the car on it.
Stan
Stan Swanson, Eerie Erie, Colorado, '67 GTV (daily driver), '71 GTV (Kyle's), '91 164 (snow car), '56 Lotus 11(gone to Oz), '59 Cadillac M+M Hearse, '74 MGB
lotuseleven is online now
post #48 of 50 (permalink) Old 04-27-2011, 08:12 AM Thread Starter
clearance
okay, here are the measurements: vertical distance from the center of the hub to the top of the forward rotisserie frame member is 31.5 inches. in the original blueprint that measurement is 34", but I lost a bit of height by mitering in my horizontal hub mount. If I had welded the mount on top of the vertical frame member, I'm closer to the blueprint spec, but I figured I was putting much smaller cars on this than the buick it was originally intended for. The width of the GTV about 6 inches back from the front edge, which is where it will cross the frame member, is less than 29" (the widest point is further back and won't interfere with anything). I should have about 3" of clearance at the closest point of potential interference. The rotisserie might not work for an american car without some extra height on the mast.
Taking PSK's comments, I will drill through and use a pin to secure the mounting framework to the hub. I don't trust just the friction of the 4 bolts, although they will let me get the height exact before I drill. hopefully a '67 and '71 GTV have the same centers of rotation so the hole works for both.
post #49 of 50 (permalink) Old 02-05-2015, 06:59 AM
classicalfas's Avatar
Did this project ever get finished? If it did please post photos of the rotisserie. Thanks, Peter.
SOROKOS likes this.
1966 GTA replica, 1967 Duetto, 1987 Quadrifoglio
1972, 1973, 1974 Montreal
classicalfas is offline
post #50 of 50 (permalink) Old 03-04-2016, 02:56 PM
SOROKOS's Avatar
Yes, You have right.
Sorokos.
SOROKOS is offline
