33 16V coolant plugs - Alfa Romeo Bulletin Board & Forums
post #1 of 2 (permalink) Old 05-10-2019, 02:56 AM Thread Starter
jram's Avatar
Hi all, can anyone help me to understand where to locate the drain plugs? I opened one of the six under block Name:  534DEB5E-9B49-44B9-9BE2-7854A74BA1C4_1557482161003.jpg
Size:  480.7 KBName:  534DEB5E-9B49-44B9-9BE2-7854A74BA1C4_1557482161003.jpg
Size:  480.7 KBand there was oil not coolant behind it!
jram is offline
post #2 of 2 (permalink) Old 05-14-2019, 10:07 PM
I think you talk about the ones on the top,if I'm not mistaken there were 4 between the cylinders and two more near the center of the block.Unfortunately,you'll need to disassemble everything around the throttle bodies.Do you know with what type of antifreeze the engine was used?
win95 is offline
Similar Threads
Aluminum Coolant Reservoir (Group Buy?) ghnl Alfetta & GTV6 (1972-1986) 44 09-28-2018 08:44 AM
Correct NGK Iridium plugs for 164S and 164B/L 3.0L Alfisto Steve 164 & 168 (1991-1995) 67 04-14-2014 07:29 AM
The latest flagship vera Lancia Thema alfa90ista Other Italian Cars 5 09-05-2009 03:32 PM
interchangeable with other makes CONNECTING RODS GTV-GR Engine Repair, Diagnostics & Rebuilding 9 07-13-2009 11:24 AM
Fouled Plugs Rustic Spider - 105 & 115 Series (1966-1994) 87 12-12-2008 03:12 PM
