1979 Alfa Romeo spider - Alfa Romeo Bulletin Board & Forums
post #1 of 8 (permalink) Old 08-20-2015, 08:45 AM Thread Starter
Cool 1979 Alfa Romeo spider
I have been experiencing an in-frequent ignition problem where the key doesn't seem to engage the motor. When I turn the key,I get silence. After leaving it for a while, the ignition will engage and the car starts. Is there someone who can help me with this issue? Gilbert from Canada
Gilbert is offline
post #2 of 8 (permalink) Old 08-20-2015, 09:59 PM
alfa tiger's Avatar
Hi, you need to remove the signal wire to the starter, put a test light on it and have some one turn the key to start mode a bunch of times. The light should light up every time. If this is the case the problem may be the starter solenoid. Of course when checking any electrical stuff make sure the battery is at full charge and all battery connections are tight and grounds are tight. If the light does not light up every time the problem is further back like relay if equipped or starter switch. Cheers Neil.
alfa tiger is offline
post #3 of 8 (permalink) Old 08-21-2015, 06:17 AM Thread Starter
Hello Neil, Thanks so much for your insight of how I can solve this matter. It's great to have some direction!
Much Appreciation! Cheers Gilbert
Gilbert is offline
post #4 of 8 (permalink) Old 08-21-2015, 08:09 AM
alfa tiger's Avatar
You're welcome, post some pics of your car, and tell us where you are located in Canada.
Cheers Neil. Ps good luck with your fault finding.
post #5 of 8 (permalink) Old 08-21-2015, 12:05 PM Thread Starter
Post picture!
How do you upload picture from your computer to the site?
Gilbert is offline
post #6 of 8 (permalink) Old 08-21-2015, 07:58 PM Thread Starter
My 1979 Alfa
Gilbert is offline
post #7 of 8 (permalink) Old 08-21-2015, 08:16 PM Thread Starter
Hi Neil! I have posted a picture of my car after it took a moment to figure out! Toronto Canada
Gilbert is offline
post #8 of 8 (permalink) Old 08-22-2015, 11:42 PM
alfa tiger's Avatar
Nice car, looks straight and rust free. Cheers Neil.
