1983 Spider radio/cassett changeout - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 1 Post By ghnl
  • 1 Post By iachella
post #1 of 9 (permalink) Old 07-06-2015, 09:47 AM Thread Starter
Local audio shop said they'd have to 'remove dash' in order to install new radio/cd player. Does this sound right?
1983arv is offline
post #2 of 9 (permalink) Old 07-06-2015, 10:32 AM
BB Janitor
ghnl's Avatar
I didn't. But I am not an audio expert. The opening in the center console might need to be cut to install a standard radio mount (I don't recall off hand if it had already been cut by a PO and I just needed to trim it for a better fit or if I made the initial cut). But for sure I didn't remove the console or dash to fit a 'modern' radio.
Do measure first to be sure you have enough depth for any radio you are considering.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is offline
post #3 of 9 (permalink) Old 07-06-2015, 10:56 AM Thread Starter
Thank you, Eric Can you tell me what make and model you installed?
1983arv is offline
post #4 of 9 (permalink) Old 07-06-2015, 03:53 PM
BB Janitor
ghnl's Avatar
It is either a Pioneer or Sony, AM/FM/CD player. (Our Spider has one of these, our GTV6 has the other.)
1983arv likes this.
- - Eric
don't read this
- -~ 1981 GTV-6 ~
ghnl is offline
post #5 of 9 (permalink) Old 07-06-2015, 08:24 PM
Farace's Avatar
Again, it depends on the radio, but removing the glovebox (which isn't necessarily easy, either) can give access to the back of the radio area.
[FONT="Century Gothic"][B]Bob Farace[/B]
[COLOR="DarkGreen"]1971 Alfa Romeo 1750 Spider Veloce[/COLOR]
[I]Director, Connecticut branch, Scuderia Non Originale[/I][/FONT]
Farace is offline
post #6 of 9 (permalink) Old 08-22-2015, 09:16 AM
iachella's Avatar
I would find a different installer. Sounds like he doesn't know Alfas and is not sure what he will run into when he starts to install. Is it a big box stereo shop or a small custom installer. My guess is the smaller shops will have more experience with different kinds of installs.
Or maybe the radio you chose has some kind of attachment that has to come from behind to secure it. At any rate, I would ask them why. Ask them to be specific as to what is it with this radio that makes them want to remove the dash.
I've actually never heard of removing a dash for a radio install. I've changed half a dozen radios from the front no problems.
1983arv likes this.
Stefano
Concord, CA
iachella [at] gmail [dot] com
iachella is offline
post #7 of 9 (permalink) Old 08-24-2015, 05:24 AM Thread Starter
The shop got it installed with no problem, so I'm happy about that. Great to have tunes again.
1983arv is offline
post #8 of 9 (permalink) Old 08-24-2015, 01:16 PM
Norseman50's Avatar
Did the shop have to remove the entire dashboard?
Edward
'88 Quad - "Claudia"
Norseman50 is offline
post #9 of 9 (permalink) Old 08-25-2015, 05:29 AM Thread Starter
NO, they didn't have to remove any of it, but had to cut the hole in the dash a little bigger to make it work. They did a very good job.
1983arv is offline
