Mechanic in Austin? - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 05-30-2019, 07:35 PM Thread Starter
wshampton's Avatar
Question Mechanic in Austin?
Hello friends --
Joe Foster was my go-to mechanic for many years. Since he has now retired, I find myself in need of help.
I have an '84 Spider. After an overheating incident, the radiator was replaced. Soon after, she overheated again and the radiator cap was found to be faulty and replaced. Since then, she won't idle or run smoothly at low RPM until warming up and then, after warming up, goes straight to overheating.
Fairly sure I need to replace the head gasket.
This is well beyond my skill- or even tool- set, so I would welcome any suggestions for Austin area help.
thanks,
-bill
-bill * Austin, TX * 1984 Spider Veloce * 1976 Vespa Rally 180
wshampton is offline
post #2 of 4 (permalink) Old 05-31-2019, 12:18 PM
Unless you are losing coolant, the symptoms you describe point to a stuck/faulty thermostat. Your car uses a generic drop-in thermostat which is both cheap and easy to install. Try a new thermostat and see if your problem goes away.
180OUT is offline
post #3 of 4 (permalink) Old 06-01-2019, 11:11 AM
Born Again Boarder
Anfanuts's Avatar
Saw Joe today at CNC. He is still working and only semi-retired from other's shops. Has a backlog of cars to work on and a nice facility. B
Anfanuts is offline
post #4 of 4 (permalink) Old 06-02-2019, 01:38 PM
Just sent you a pvt. mssg. with Joe's phone number. He's still working on Alfas.
180OUT is offline
