1986 gtv6 - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 1 Post By Eman911
  • 1 Post By Sekal1978
post #1 of 10 (permalink) Old 08-16-2019, 04:46 PM Thread Starter
Sekal1978's Avatar
1986 gtv6
Recommendations.
1986 gtv6 inner and outer tie rods.
Need to replace and need some good ones to buy.
Sekal1978 is offline
post #2 of 10 (permalink) Old 08-16-2019, 08:05 PM
Member
otteud96's Avatar
That car has a steering rack it has no inner tierod but yhere us a joint that connects it to the rack. Good luck
otteud96 is online now
post #3 of 10 (permalink) Old 08-16-2019, 08:36 PM
slowcreek's Avatar
Buy from any of Alfa BB's Vendors.
It's Giuseppe's giubos, not Guido's guibos, on my 78 Spider and Sport Sedan
slowcreek is offline
post #4 of 10 (permalink) Old 08-17-2019, 09:56 AM
crackie's Avatar
I think the inner is actually hard to find unless someone has started producing it again. It’s different than a Milano, which is still available. When I needed one I found it at Alfa Parts in Berkeley (aka Jon Norman).
--Scott
Current: 85 GTV6, 69 Duetto, 17 Giulia, 74 GTV
Past: 65 Giulia Sprint GT, 77 Alfetta, 79 Alfetta, 87 Milano Gold, 74 GTV (Euro)
crackie is offline
post #5 of 10 (permalink) Old 08-17-2019, 03:04 PM
I used a Moog part for a 90's Dodge Caravan when I redid my Alfetta. All I had to do was cut the excess length off. Inner and outer threads were the same. I believe the GTV6 has the same inner as the alfetta.
ballough510 likes this.
Eman911 is offline
post #6 of 10 (permalink) Old 08-17-2019, 08:19 PM
Well, the term "inner tie rod" on a car with a steering rack refers to the ball-and-socket joint that threads into either end of the rack. So yes, there is an inner tie rod available for the GTV6, I replaced the them on my '81 (hilariously known as "snodos" in Italian), got them from Alfissimo.
Chris A: '81 GTV6 rescued from junkyard, "GT" car/'86 Porsche 944 Turbo track/street car/'73 BMW 2002tii fun street car/'74 Jensen Healey Lemons Rally car!
cda951 is offline
post #7 of 10 (permalink) Old 08-18-2019, 06:50 AM
I bought my inner ones from DiFatta Bro's several years ago. They were OEM and the last ones that they had.
2011 Jaguar XKR
alfaparticle is offline
post #8 of 10 (permalink) Old 08-20-2019, 07:21 PM
Hydro's Avatar
If you can't find OEM ones, you can use 87 Toyota Supra (not turbo) parts. Right side - ev281, left side - ev243.
Randy S.
Hydro is offline
post #9 of 10 (permalink) Old 08-21-2019, 08:03 AM
racingswim2006's Avatar
I've used Milano tie rods probably a dozen times. They work fine - and I ALWAYS remove the steering damper. The Italian made ones from Centerline are quite nice.
Rob
racingswim2006 is offline
post #10 of 10 (permalink) Old 09-17-2019, 07:54 AM Thread Starter
Sekal1978's Avatar
Part number. That is the question. I know alfa, BMW, Toyota volvo and probably others share same/ similar parts and maybe you won't find any part when searching for 1986 Alfa gtv6 inner rod but if you go with the part number you will find it. That goes for almost every car and every part number. Funny how no one compilated a part number book over the years. I'd be up for it. That milano or the Toyota might be a good way to go. Are they exact fit or do they need tinkering? Lolololol
gtvgeoff likes this.
