Corner weighed my 78 Sport Sedan - Alfa Romeo Bulletin Board & Forums
 6Likes
post #1 of 19 (permalink) Old 05-04-2019, 07:31 PM Thread Starter
slowcreek's Avatar
Here's the results
It's Giuseppe's giubos, not Guido's guibos, on my 78 Alfas
slowcreek is online now
post #2 of 19 (permalink) Old 05-04-2019, 07:34 PM
Does that indicate that there is too much weight on the front left? Can it be corrected by adjusting the left torsion bar?
85 GTV6 3L
2011 Jaguar XKR
alfaparticle is online now
post #3 of 19 (permalink) Old 05-04-2019, 07:40 PM Thread Starter
slowcreek's Avatar
I don't know......LOL. I thought you would!!
Now, I'll add something. Without me in the car, the measurement from ground to fender lip LF is over an inch higher than RF.
Put my 195 pounds in the driver seat and the LF is only 1/4" higher than RF.
The Sport Sedans have real soft suspension.
post #4 of 19 (permalink) Old 05-04-2019, 08:01 PM
Always disconnect sway bars for cornerweight, adjust as needed. Only then, CW with SB after you are done and happy without. Then, set SBs for same as without, or use SB for correction IF desired.
You are 211 pounds, and the springs and/or SBs need to be adjusted (but you can't know which it is unless you disconnect SBs and CB again). You are heavy left-front/rt-rear - both with and without your 211 pounds. In other words, it does not matter if you go on a diet, it won't help. The car will over steer left and under steer right - if you care, or push it to the point of knowing either way.
PS: assuming you are working with leveled CWs - commonly adding meaningful inaccuracies - yet not able to explain away 195 v 211 body weight, more likely due to winter feeding habbits.
Alfaboutvegas likes this.
guillotineFI is offline
post #5 of 19 (permalink) Old 05-04-2019, 08:05 PM Thread Starter
slowcreek's Avatar
Originally Posted by guillotineFI View Post
Always disconnect sway bars for cornerweight, adjust as needed and then with SB after you are done and happy without. Then, set SBs for same as without.
I never thought of that.
It's just a street car and I only weighed it because my buddy had a set of scales.
post #6 of 19 (permalink) Old 05-04-2019, 08:37 PM
Honestly, I don't know at what percent of CW you would be able to tell any handling issue on the street. I doubt you would be able to tell. Just commenting on the theory, and of you went to the track with it, you could definitely make some spring/SB adjustments - assuming you have scales handy.
post #7 of 19 (permalink) Old 05-04-2019, 08:51 PM Thread Starter
slowcreek's Avatar
Scales are at my disposal. I found it interesting that it was as close as it is. And, 50/50 front to rear.
It's nice having friends with scales and chassis dyno.
post #8 of 19 (permalink) Old 05-04-2019, 09:05 PM
The greatest challenge in working with CW scales is getting a level set-up. Before making any changes to your car, you should find a way to check if your scales represent a level surface - using laser levels for instance. To see how much it matters, throw a 1/4" shim under one wheel, and see how much it throws off your scale readings. This can also give you an idea of practical tolerance - and then you can decide if it's worth making any changes.
Then again, driving it at the limit - as long as it's balanced, then - well it's good!
post #9 of 19 (permalink) Old 05-06-2019, 09:20 AM
Cool info - thank you. You can take around 110 lbs off by removing the bumpers. Makes a difference you can feel.
On the suspension, you get used to it and its part of the drama. I drove my BMW 335i after the Alfa and it felt absolutely boring at any speed under 75 mph.
Ranz likes this.
1978 Alfetta Sport Sedan | 1985 GTV Lemons Racer
Instagram: Alfaddiction
peakay is offline
post #10 of 19 (permalink) Old 05-06-2019, 01:45 PM Thread Starter
slowcreek's Avatar
I hate those bumpers. I discharged the absorbers and slid them back. I wish the weight wasn't there and it would look good without the rear.
post #11 of 19 (permalink) Old 05-07-2019, 06:54 AM
The goal of corner weighting is to get the cross weights (the sum of the left front and right rear, and the sum of the right front and left rear) as close to 50% as possible to ensure similar performance in left and right turns. That is the theory, at least.
In your case, you would lower the left front by a small amount in an attempt to transfer some weight to the right rear, which would also have a small effect on the other corners. I assume that your Alfetta is stock and doesn't have adjustable rear coilover springs, which limits your adjustability.
I am not a fan of going overboard with fine-tuning the corner balance of a street car with rubber bushings, as the friction of those bushings affects the results (spherical bushings are better for this). Plus, you often end up adjusting the ride height of some corners too much in an attempt to get the cross weights perfect, which means that the suspension geometry is slightly different side to side, which kind of defeats the purpose of corner balancing in the first place.
Real race cars corner balance by moving weight around the car!
alfaparticle and horsewidower like this.
Chris A: '81 GTV6 rescued from junkyard, "GT" car/'86 Porsche 944 Turbo track/street car/'73 BMW 2002tii fun street car/'74 Jensen Healey Lemons Rally car!
cda951 is online now
post #12 of 19 (permalink) Old 05-07-2019, 07:00 AM Thread Starter
slowcreek's Avatar
I don't have any real goal here other than satisfying curiosity, and a friend who has the scales and a chassis dyno at his home.
I am gonna drop the LF down that 1/4" because it bugs me and I'm putting my Koni Yellows on soon. Should be here today.
I'll weigh it again at some time.
horsewidower likes this.
post #13 of 19 (permalink) Old 05-07-2019, 03:14 PM
Oh, good for you. they were such a PITA to remove I did not wan to reinstall them. To me, the front bumper mounts sticking out looks worse and I thought the whole thing looked better. I'm either having a small bumper/light bar fabbed for the front or hanging driving lights off of them and putting some plates on the back or gluing some chunky rubber squares in that spot. Mine is black though, so it blends a little better.
peakay is offline
post #14 of 19 (permalink) Old 05-07-2019, 03:51 PM
Ranz's Avatar
I think the bumperless look suits the Alfetta sedans as much as it does on a Stepnose. It really lightens the look, even with the smaller Euro bumpers we got here in OZ.
Ranz is online now
post #15 of 19 (permalink) Old 05-07-2019, 05:58 PM Thread Starter
slowcreek's Avatar
It really does. Unfortunately the 4 bolt pads for the bumper look awful.
Similar Threads
Sport Sedan Steering Wheel Hub Adapter pc77 Alfetta & GTV6 (1972-1986) 0 12-06-2011 05:24 PM
Wanted: Alfetta Sport Sedan Euro Bumpers Neil Martin Alfa Romeo Parts For Sale & Wanted 3 11-10-2011 04:03 PM
For Sale: 1979 ALFA ROMEO ALFETTA SPORT SEDAN AUTOMATIC w/ MODS! Italisti Alfa Romeo Cars For Sale & Wanted 4 06-24-2010 07:26 PM
For Sale: 78 Alfetta Sport Sedan: parting out bjwhite Alfa Romeo Parts For Sale & Wanted 24 06-17-2010 07:24 PM
Sport Sedan Dashboard randyleepublic Alfetta & GTV6 (1972-1986) 7 12-17-2009 12:17 PM
