Where to find GTV6 speedo sender - Alfa Romeo Bulletin Board & Forums
post #1 of 9 (permalink) Old 02-26-2019, 09:41 AM Thread Starter
The speedometer in my GTV6 usually doesn't work but every so often for a few thrilling minutes, it works normally. I swapped speedos to another one and it seems to work with the same rarity. My assumption is that it's the sender at the transaxle. Where can I get one of those?
Thanks!
SpintoVeloce is offline
post #2 of 9 (permalink) Old 02-26-2019, 10:16 AM
Mark_toro's Avatar
Assuming that you have the original transaxle in the car (not a Milano swap), there are two different types of senders that are not interchangeable. Early type has a gear drive that interfaces with a gear on a shaft in the transaxle (model year up to 85.5). The late type has an inductive pickup that reads teeth on the the shaft (model year 85.5 and 86).
If yours is the early type, I have a sender that tested functional. $30 plus shipping. Before you spend $ though take a look at the wiring at the sender. It is on the LH side of the transaxle and corrosion can take a toll on the connectors.
PM me if you are interested in the sender.
Mark
84 Spider - Long gone, but started the addiction; 85 GTV6 - Current project, Supercharged, Mega Squirt; 88 Verde - "Milo" It has a name, must be a keeper
Mark_toro is offline
post #3 of 9 (permalink) Old 02-26-2019, 12:12 PM Thread Starter
Mark
Great, many thanks! Will send a PM.
post #4 of 9 (permalink) Old 03-01-2019, 10:05 AM Thread Starter
Still looking if anyone has any pointers.
post #5 of 9 (permalink) Old 03-01-2019, 11:45 AM
What year is your GTV6? As Mark posted, there are two different types.
2011 Jaguar XKR
alfaparticle is online now
post #6 of 9 (permalink) Old 03-01-2019, 04:48 PM Thread Starter
Sorry, it's an 82 so I need the early type of sender.
post #7 of 9 (permalink) Old 03-01-2019, 06:39 PM
Try Larry at Alfa Parts Exchange (APE) in California.
2011 Jaguar XKR
post #8 of 9 (permalink) Old 03-01-2019, 07:54 PM
racingswim2006's Avatar
I have a new old stock early sender, still in Alfa box. Fits 81 to 85 GTV6. PM me if you cant find one.
Sent from my SM-G935V using Tapatalk
Rob
racingswim2006 is offline
post #9 of 9 (permalink) Old 03-02-2019, 07:09 AM
If it works every now and then it will be because the solder joints on the connector have cracked. It is pretty simple to resolder them - although a bit finicky. The real problem is access as the bad joints are inside the unit. The unit is sealed and you need to open it by cutting the metal ring which holds the front plastic bit with the plug onto the rear metal body. A clean thin cut with a dremel works well, you can then prise the ring off, resolder the joints, and then put it back together using the cut metal ring and a hose clamp to secure it. Mine worked for 20 years after doing this. I think I have a couple of photos somewhere - I'll try to dig them up but they are on an old phone about 4,000 miles away so no promises.
tpalfa is offline
Similar Threads
Interval Service This Week GTV6 and Speedo Sender Question 8oclock Alfetta & GTV6 (1972-1986) 7 07-27-2016 05:21 AM
For Sale: hard to find GTV6 and Milano parts racingswim2006 Alfa Romeo Parts For Sale & Wanted 3 11-11-2013 09:14 PM
Wanted: 1982 GTV6 speedo sender bill2000 Alfa Romeo Parts For Sale & Wanted 2 12-25-2012 02:01 PM
Speedo that fits and works in your gtv6 and milano tranny sfloridalfa Alfa Romeo Parts For Sale & Wanted 3 02-13-2012 08:20 AM
Speedo reading low - sender or dash? evilgidget 164 & 168 (1991-1995) 0 09-15-2005 01:22 AM
