Alfetta GT Heater Control Light - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 11-21-2018, 09:32 PM Thread Starter
ncng's Avatar
I am a dufas, I have been renewing my fuses and light bulbs tonight from stuff I just got in
from Centerline. Even though it was working, I renewed my heater control bulb ( I have no AC),
heater controls were lighted before, but now I cannot figure out where to put it back to light my heater
controls as before? See attached photo taken in the dark, this area is usually lighted. Not since
I f'ed it up, thanks for your help, Happy Thanksgiving,
ncng
ncng is offline
post #2 of 4 (permalink) Old 11-22-2018, 03:03 PM Thread Starter
ncng's Avatar
Fixed it, I was trying find a place for the "Fasten Your Seat Belt" light to light my heater controls, found the standard side switch bulbs, however created a crazy new issue, heater fan was working with two speeds, now it works at full speed no matter what position the switch is in, I must have two wire touching? ncng
ncng is offline
post #3 of 4 (permalink) Old 11-28-2018, 06:28 AM
iachella's Avatar
Mine has been that way for years. It coincides with work I did to the area. I just assumed the switch went bad. Let me know if you figure that out.
Stefano
Concord, CA
iachella [at] gmail [dot] com
iachella is offline
post #4 of 4 (permalink) Old 11-28-2018, 06:51 PM Thread Starter
ncng's Avatar
You have to pull out "carefully" the fan switch, it comes straight out. on the side of the switch are two rectangular sleeves that hold the 1.2v lights,
with both bulbs working it will light the clear panel pretty well. I got replacement bulbs from Centerline - see link below
https://centerlinealfa.com/catalog/instrument-bulb-18mm
ncng is offline
